Heritage Tropical 04
Langley / BC / Canada
I have a 2door side by side fridge with an ice maker it frosts up in a few days any ideas why, what can i do to prevent it.
2004 Tropical T370
Golden_HVAC
Fulltime, CA, USA
Hi,
You can do the "Dollar Bill Test" and see if the gasket is a little weak. Close the door on a dollar, and see if it pulls out easiely, and then move the dollar up and down the gasket, to see if there is a gap.
Usually it is humidity leaking into the freezer that causes the frost.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
buchrob
Stanstead QC
Maybe a bad door seal. Try cleaning the door frame and rubber gaskets with rubbing alcohol.
Many rigs will make a sound as if the air is being sucked out of the fridge or freezer when the door is first closed.
Frost = moisture.
Then, you should look up the mfgr web site FIRST with the Model and Serial numbers in hand. They can usually give pointers.
Otherwise, you may get a lot of unhelpful flak from here, but maybe the occasional useful comment if we know make and model of the compnent, not the rig itself.
'99 Glendale Royal Expedition 24' Class C
2003 Subaru WRX wagon as toad.
HIDEOUT
San Francisco Bay Area
I bought a no frost deep freezer for my garage. The garage temp is not controlled and the freezer was icing up. I put a 25lb weight on the lid and it stopped about 75% of the problem. Like the others have said, probably a seal leak. Moisture from the air collects in low temps kind of like dew does on your car windows. Good luck.
Kevin & Dawn
Doggies:
Persalina, We love you & miss you so very much!
Moonbeam
Chloie Pearl
'07 Itasca Suncruiser 35L
Workhorse 24-8.1 Vortec w/6 sp. Allison
93 Jeep Wrangler Toad
Roadmaster Even Brake
Think before you Wink or Blink or Dink-a-Doo
Big_Eck
Cold Canada
DOES YOUR FRIDGE HAVE THE OUTDOOR HOSE THAT GOES INTO THE DRIP DRAY?
mine is supposed to be in water, I think it has something to do with the moisture if i remember
2004 Holiday Rambler Endeavour 40 foot 3 slides
10 year friend of Bill W
Driven over 200 New units of all kinds and descriptions
"...there are two types of rv'ers, those that camp and those that camp at a NASCAR race..."nascarcamping.com
grinder
Courtenay, British Columbia
Another thing we have found is that putting warm items in the fridge seems to frost it faster. So we now cool before putting away. Humidity in the outside air has a lot to do with it also. Try not to keep the door open as long. Just a few suggestions.
Ted
Courtenay, BC
Wherever I happen to park
Do not open the door.. (I'm serious)
When you open the door warm moist air enters the Fridge, when it hits the fins at the back the moisture condenses out, the fins are cold, often below freezing, thus frost forms. This is normal operation. The only "Cure" is to occasionally empty it out, turn it off, let it melt and dry, and re-start it
Moving air (use of a fridge fan) MAY, and I stress MAY, warm the fins enough to cut down on it. But frankly... I doubt it.
sun bird
Charleston, SC
Don't know how to stop it, but easy to defrost using hand held hair dryer. wipe water up w/sponge and be done quickly.
r1chy
Fairfax, VA
Contact the refrigerator manufacture and ask the tech department if the model you have has a defrost circuit - if so then it may be bad. Depending upon the method they use it could be a simple DIY fix.
Good luck and let us know if/how you resolve your problem.
R1chy
Fleetwood Revolution - 2002
Nick Badame Refrig.
Cape May Court House, N.J.
Golden_HVAC wrote: Hi,
Fred.
Fred forgot to mention that it has to be a hundred dollar bill to properly test the gasket seal....
I love this board!
Nick-
MCI 102C3 40' 2006' Bus Conversion by Atlantic Custom Coach
Detroit 475hp 8V92t w/Allison Ht750 auto
Master Mason, Cannon Lodge #104 S. Seaville N.J.
FMCA# F-27317-S
