Albertaguy
Calgary Alberta
alibatesknapper wrote: I've used the car wash for years, just make sure the bay is tall enough. I saw someone take their air conditioner off once.
Yep, I know what you mean. It almost happened to me last summer and this place was billed as a Truck and RV wash.
jauguston
Bellingham, WA
t10,
If there was a way to do a satisfactory wax job on a vehicle it would be common knowledge. You have to rub it.
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
lzasitko
Regina, SK Canada
I have used a pressure washer and never an issue. I have an older MH so no vinyl decals my strips are real paint. I do have a long handle brush so I spray all the loose stuff off, then use the brush and soap and then spray it off with the pressure washer. I never get it close enough to do any damage.
Roy T
Dodge City, Kansas
I've always hand washed. I've been thinking about a pressure washer used at a distance in conjunction with a brush. I think as long as you keep the high pressure at the end of the wand away, you will be ok to rinse/wash. I would also like to hear more on this.
CardMan
Saugerties, NY
I bought a 1700psi electric pressure washer from Sam's Club and it works great. It gets 75% of the dirt/grim off but you always have to brush it.
Its nice for those quick spray offs between the good deep cleans. Again you just have to watch around the decals but you just have to use common sense!
TV: 2003 D2500HD 4X4 W/ HEMI - Timbrens, Prodigy, Reese 15k w/Slider, Line X
TT: 2004 Cardinal 31LX2BH
chickadee
N.C.
Our contact at Forest River says do not use pressure washer on our unit. Hubby uses long handle brush while I rinse. Don't take us long at all.
Hubby Me
One Spoiled Maltese (Puddles)
03 Ford F-250 Super Duty Super Cab SB 4 x 4
06 Rockwood 5th wheel 8283SS (Forest River)
ReVoker
Corlista, RJ
I have a 3000 psi washer that I got at Northern Tool. I use it from a distance to get everything wet (and soapy with the chemical injector) using a low pressure nozzle. I use a long handle brush and a mid-pressure nozzle to clean it off. Never have had any problem with decals doing this so far but the bugs fly right off. Once I have the soap rinsed I use the pressure washer to put on liquid wax. Let is dry and I'm done.
ReVoker
An opinion on every subject...
Btravelen
N. IL
The 'trick to using a pressure washer is avoiding potential problem areas, like around decals, window or other seals. They require a 'touch' and can be dangerous if used carelessly.
Take Care
2000 Ford Excursion V10 (SOLD) 2005 Exc. 6.0L PSD, 2wd, 3.73LS, Air Lifts with Load Controller II, towing '00 31SKS Holiday Rambler Alumascape with a '01 Hensley.
HaroldG
So. Cal
I use a pressure washer for first rinse (at a distance),then use a brush to wash and pressure washer (at a distance) to rinse.
Harold
jauguston
Bellingham, WA
It sounds like those that do use a pressure washer use it "At a distance". Sounds like the same result you would get using a hose with a nozzle (-:
Asside from cleaning the wheels and tires I keep my pressure washer from my coach.
jim
