RV.Net Open Roads Forum: Toy Haulers: My wacky grey water filter experiment.
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > My wacky grey water filter experiment.
beavergod1
austin, texas, usa
Posted: 04/21/08 07:42am Link  |  Quote  |  Print  |  Notify Moderator
At home I keep the grey water cracked open and let it dribble onto the ground in the backyard. Got to be cleaner than whats coming out of my septic system. If camping without full hookups I will drain 5 gal at a time into my 5 gal blue tote and dump it around a tree or bush at night. I make sure it not near any fresh water source though.
Friends: Easy to make and hard to get rid of.
r1Mk
modesto, ca
Posted: 04/21/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
I'm still waiting to hear about the taste test.
'06 GMC 2500HD D/A 4X4
'07 Crossforce 33MK
Winter Arctic Cat 900 1M, Polaris 700 RMK, Polaris 550 RMK
Summer Honda 300 EX, Yamaha 80, Polaris 50
Strabo
Desert Dweller
Posted: 04/21/08 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Bottle the stuff....Name it: GreyGold Natural RV Water, bottled at the source using high tech filtration system consisting of an old Nylon...
0 carbs, low sodium, tastes great.....
2005 Ford F150 SC FX4-Procomp 6" lift-Fabtec Lightbar-Magnaflow 3" CB-K&N C.A.I-Firestone Airbags-Prodigy-Overhead DVD
2003 24' Jayco Talon ZX TH
2007 Rhino 660 SS106-ITP-K&N-JetKit-T4-CDI-CVT-Grant-Holder LED LightBar
1992 CR 250
1995 KX 250
longwayfromhome
Alaska
Posted: 04/21/08 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Start with full fresh tank. Water gets used for dishes and shower, goes into grey tank. Process grey tank output and return to fresh tank. Endless loop almost, barring evaporation and incidental loss from gunk filter. Right?
Any excess grey water that surpasses system capacity, coming from outside sources such as water bottles/jugs, rather than fresh tank, gets pulled from a valve in the top portion of the grey tank to be used for toilet rinsing.
Finally, process the sewage juice and port back to grey tank which, in turn, effectively double processes it back to the fresh tank.
There, we can now dry camp until the filtered "solid" sewage removes all moisture from the system. It may be possible, if you drink lots of bottled water or canned beverages that you could go forever.
Problem solved. Wait. Was there a problem?
barry&vanda
Vancouver BC Canada
Posted: 04/21/08 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
NASA has already solved your problem. Their system even turns pee into drinking water. An RVer's kit is available. Cost - $38 Million (plus shipping & handling).
Re: Grey water routed to flush toilet: Do you know how stinky your grey water is??? After a while, your rig would smell so bad, you'd give up RVing!
Next idea?
Honk at any silver Dodge Ram & Crossterrain toyhauler on Baja. It's gotta be us - 'specially if it says Baja and Back #1.
05 Dodge Ram 3500 Diesel 4 by w/10,000 lb winch
09 TF34MK Crossterrain toyhauler
12' Portabote w/Yammy O/B.
08 Honda Rancher ES
portscanner
Georgia
Posted: 04/21/08 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
thinkpt wrote:
portscanner wrote:
The OP has brought up an interesting concept. Now take it to the next logical step. Put just a particulate filter on a line leading from the gray tank to a water pump. Connect the pump to the toilet. This will reduce your fresh water usage and extend your gray water tank.
Of course you would need some gray water in the first place in order to flush....
Now we are talking! Put a valve between fresh and grey at toilet, after a day, switch valve and use grey for flushing rest of trip. Lets make a kit and sell for a fortune. We may even get the greenies to love us.
I would be concerned that if you dont have a reliable anti-backflow device and the valve fails, you will have some rather tasty fresh water.
One beautiful wife, one beagle, two brittney spaniels
2005 F250 SD Diesel 6.0
2007 WW SL2805
Web Site
Macs Dad
SoCal
Posted: 04/21/08 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
Saw a guy last year dumping at the Dump Station at Doheny. He had some sort of waste grinder on his RV that the grey and black water is connected to. He turns the thing on while he's dumping and it grinds everything small enough to be dumped from a garden hose. Really fast to. Maybe that would solve the filter clog issue.
* This post was edited 04/21/08 06:44pm by Macs Dad *
07 Weekend Warrior SL2805
05 Chevy 2500 HD Crew Cab 6.0/410 Gasser
05 Honda 400 EX
07 Twister 150 GT
03 Honda CR 125
grampachet
West Coast
Posted: 04/24/08 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
If you used your grey water to flush your toilet I would be concerned with the particles in the galley water eventually building up in the valve and not allowing your toilet to seal properly.
2004 F-250 KR,CC,SB,SRW,4x4,V-10,3.73
2008 Montana 3000RK
Strabo
Desert Dweller
Posted: 04/25/08 12:32am Link  |  Quote  |  Print  |  Notify Moderator
RV FoodProccesor or Macerator as commonly known. I like reading the wacky contraptions Al has invented, interesting stuff if you ask me.....
Born2RV
Miami, FL. USA
Posted: 04/25/08 11:50am Link  |  Quote  |  Print  |  Notify Moderator
I could never figure out what the Macerator was for until I spent 12 days boondocking. We used it to dump the black water tank into a port-a-potty. Worked good.
In northern Ohio, campgrounds do not generally have individual sewer hookups. They have a french drain for gray water and a honey-doo truck comes around for the black water. Had to buy a new cap for the gray water drain that allowed me to connect a hose. Worked OK.... Keep up the good work! You never know what will catch on and make you a millionaire!!
2007 Freightliner M2 Mountain Master (will work for fuel!)
2006 KZ New Vision Sportster
former 2006 F250
former KZ Sportster 29p
former 1995 Coach House 192TB
Live long & prosper
