RV.Net Open Roads Forum: Tech Issues: Battery Amp Hour
 > Battery Amp Hour
ResearchMan67
Seminole, Fl, USA
Posted: 04/19/08 07:17am Link  |  Quote  |  Print  |  Notify Moderator
easiest way to find AH if you can't read on the batteries?
manuals are worthless and so is the Winne website.
Thanks.
ResearchMan67
2007 Winnebago Tour 40TD, 400hp Cummins, Freightliner/Allison,
Saturn VUE (6cyl/auto/FWD-2004), BlueOx,Adventa II
brobox
Sunny SW. Florida
Posted: 04/19/08 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Go to the battery manufactures web site and check your model battery. the specs for the battery and the amp hours should be listed there.
Chuck
02 Travel Supreme, 2 street side slides
02 Jeep Liberty Toad
RJsfishin
Winston Or.
Posted: 04/19/08 07:55am Link  |  Quote  |  Print  |  Notify Moderator
If you're talking deep cycle RV Marine Trolling motor batteries,.......
The smaller group 24 has 70-85 AHs
The larger group 27 has 100-115 AHs
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
pulsar
Lewisville, NC
Posted: 04/19/08 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Technology Corner to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
ResearchMan67
Seminole, Fl, USA
Posted: 04/19/08 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
There is a Group 31 sticker on each of (3)house batteries, but I don't recall any name brand; I'll have to look again. I did check Sam's club today per one suggestion and they had some Gp31 batteries, but they also did not have anything about AH, and only said CCA--I don't want/care about the engine battery at this time. Doubt these were even deep cycle, but am looking for what the Group 31 is really telling me.
Here's another question: If the dual 6volts are so much better than 12's for house use, why aren't any of the manufacturers using them?
smkettner
Posted: 04/19/08 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Group 31 should be 110 to 130 amp hours. The group number is the physical size. Group 29 is esentially the same and a bit more common (WM or Interstate).
RJsfishin
Winston Or.
Posted: 04/19/08 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Several RV mfgs use 6v batteries as OEM. And who says their better ?
Amp hour capacity is basically the same,....no matter what you mite hear or read. But if one can read specifications, then one knows that already.
Reports have shown longivity to favor the 6v batts. But I believe, if maintained properly, and not abused, 12v batts to be just fine as house batts in RVs. The 12v deep cycle in my boat (a blem name unknown) is going on 8 yrs old, and still working fine. But it has been on a float charger 24-365, and has never been low on water.
Pete D
Washington
Posted: 04/19/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
My opinion is that the original 12V batteries were whatever the manf could find at inexpensive price. Standard size, standard voltage, standard box, etc.
If replaced with golf cart batts, they are slightly larger (hold a few more amp-hours for that reason) and they are made to last longer than the previous 12Vs were, so they do.
IOW, I don't think the same kind or quality of batteries is being compared.
1998 Ranger 4.0 4x4
1991 Scamp 13'
ResearchMan67
Seminole, Fl, USA
Posted: 04/19/08 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, thanks all, I'm going to replace with 12's again.
Now: I'm leaning toward same standards vs. Gels (i.e. can replace them twice for price of gel) -- I do like the maintenance free part though.
Kinda leaning toward Interstate or Wally World, just because of availablity on the road?
chuck4788
West of the Middle
Posted: 04/19/08 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Deep cycle batteries use different plate composition than starting batteries.
Amphour capacity is directly related to the quantity of lead in the battery, and CCA capacity is related to the surface area of the plates. The result is starting batteries have a lot of thin plates for max surface area and deep cycle batteries have a larger volume of lead in fewer plates.
If a battery has a CCA and/or MCA rating it is a starting battery, deep cycle batteries won't have these ratings. Some dual purpose will have both, and be optinal for neither task.
If you don't do much dry camping, or don't mind running the genny a lot, amphour capacity is not so important. On the other hand; we're currently on the road and haven't had shorepower for six days, we will find a dump station tomorrow, but no power for another two days. Just another adventure in battery management.
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
 > Battery Amp Hour
