Movin' on
western Ohio
It looks like I'm in the minority here, but I took ours back. It was too big and hard to hold and I didn't like the fine stream that hits you right in the face when you're soaping up. I thought it would have a heavier spray than our old one but not much difference. It wouldn't stay in the holder very well either. I decided I really liked our old one that just trickles while soaping up. To each his own I guess.
2000 Newmar Dutchstar 3365 V-10/Banks
2004 Saturn Vue V6
Choxnpinz
MUCH too young to be a
I just got mine from CW today and since we're out camping, I decided to install it. I dunno, maybe mine is broken, but the water volume and pressure are well BELOW what the OEM el-cheapo head gave. At first I thought it was the valve that turns it off, but it varies the water from dribble to trickle. So I took that piece OUT and ran it straight to the faucet. No noticeable difference. I'm hooked up on park water right now (at 60 psi). I may try filling the fresh tank and seeing if the water pump gives any different results. Stay tuned.
Cheers!
Chris
http://www.choxnpinz.com
2006 Nissan Titan SE
2009 Rockwood Signature Ultralite 8315BSS
2 part-time teenage daughters (18 and 20)
The Texan
Summer: A Cool Climate Winter: A Warm Climate
Choxnpinz wrote: I just got mine from CW today and since we're out camping, I decided to install it. I dunno, maybe mine is broken, but the water volume and pressure are well BELOW what the OEM el-cheapo head gave. At first I thought it was the valve that turns it off, but it varies the water from dribble to trickle. So I took that piece OUT and ran it straight to the faucet. No noticeable difference. I'm hooked up on park water right now (at 60 psi). I may try filling the fresh tank and seeing if the water pump gives any different results. Stay tuned. Take it back to CW and get another, that one's broke.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03
FMCA #F203528
'05 HR Endeavor, 40PRQ w/400 Cummins - With -'05 GMC Sierra SLT, CC Z-71, the pusher
'07 Arctic Cat 500A & Wilderness Kayak, riding in the pusher -
Our Current Location
Anthony21403
Arkansas
I ordered one while I was deployed to Iraq and installed it when I got back. I love it. Great shower, and uses less water. If you do a search in all the posts, you will find one that tells what part number to get for a shutoff at Lowe's that will work good with it. Also, it was a post on here that pointed me to where I got it. 29.99. Best price I have found on it, and I have not been disappointed. Just my 25 cents worth (inflation ya know)/
TSG Tony, USAF, 17 years
Choxnpinz
The Texan wrote: Take it back to CW and get another, that one's broke.
I tried running it from the fresh tank using the pump and it made no difference. When I get home today I'm going to try pulling the whole house water filter out and see if THAT helps. The other possible culprit is the city inlet line. Once I hook up the city water, the line it goes to inside the camper has the diameter of a pencil. I don't know why they'd do that, but it makes for lousy flow from ALL spigots in the camper.
First things first. I'm going to try removing the filter, then maybe drill out the restrictors in the line, then if it still doesn't work I'll see what I've gotta do to replace the inlet line with a NORMAL line that allows full flow.
Bumpyroad
Virginia
Choxnpinz wrote: The Texan wrote: Take it back to CW and get another, that one's broke.
If it won't run right on the tank/pump then you are trying a lot of things there that have no effect.
bumpy
N9MB
Indiana
We bought our friends one for their class a for Christmas and they love it. They say it does great even when the water pressure is low.
F350 PSD CC DRW Tow Boss
Heartland Bighorn 3600RE
Airsafe Revolution
TajMahallin
Belgrade MT
We purchased on back in February and will be able to use it this weekend as it's our first weekend out this season.
Happy RVing!
Scott & Margo
Daughter (11)
Dusty (Aussie X) & Kadie (Cairn Terrier)
2006 Chev Silverado 3500 LT Quad Cab LB Duramax/Allison
2007 Cedar Creek 36RLTS Custom
"May you live as long as you want and may you never want as long as you live."
Our Webpage
