jamorgan3777
Appleton Wisconsin
I am fairly sure its working properly, but its pretty loud. Its bolted to the floor of the TT. I know there are isolator kits, but what home brew solutions are out there? I'd like to fix this.
Thanks!
2003 Chevy Silverado Z71 5.8L V-8 3.73
2007 Jayco JayFeather EXP 29A
1972 DH
1974 DW
2000 DD
2001 DD
2003 DD
2005 Rosie the high$ wonder-mutt
Chuck&Gail
In the Colorado Mountains
Ours was loud. I took the water line between the tank and the pump and replaced it with a longer line that made a loop. Noise was then much less, so I never tried step two, floor isolation. So try that first, maybe you'll be lucky like we were.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
2oldman
WA
The easiest fix is to go to HD or Lowe's and get a flexible sink line. Then replace the pump's output line with it. The noise usually comes from the water hammer noise transferred to the coach's hard plumbing lines via the stiff output hose.
The Dude Dad
Simi Valley, CA
I took a pool noodle and cut it to fit around part of the pipe that was banging against the floor. Now the pump is quiet as can be and it was a cheap fix.
2007 Thor Wave 26RLS
2004 Chevy 2500HD Gas Hog
DW Michelle, Son Tyler, Daughter Kaitlyn, and one on the way!
wrenchbender
Phx
Along with the above, you may try mounting the pump on rubber hose.If all else fails invest in a centrifical pump and accumalator.
rrupert
NW PA (Oil Heritage Region)
Somebody on here said he placed a mouse pad between the pump and the floor. It supposedly worked very well.
Joyce and Rich
2005 HiLo 1705T
2007 Fleetwood Sun Valley Popup (Our 5th PUP)
2007 Toyota Tacoma Crewcab
Amatuer Radio K3EXU
robbie69
wauconda, il usa
i installed the hose kit(2 hoses) from CW and was surprized at the difference.
even the DW couldn't beleive it and she was the one it seemed to bother the most.
don't think i'd want to completely eliminate it-it would be a good early warning if the plumping should develope a leak anywhere.
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
Dick_B
Palos Heights, IL USA
You could search this forum for Pump then the results for Noisy for more responses.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
mobil1racing
Northern, WI
The Dude Dad wrote: I took a pool noodle and cut it to fit around part of the pipe that was banging against the floor. Now the pump is quiet as can be and it was a cheap fix.
Do you have a photo of this??
2005 Ford F-150 Lariat
2007 26 FBSS Puma, XM Radio,
Beautiful wife,
2 Kids, a
Yellow lab(Kramer) and
a Brittany(Newman)
Garfie|d
South-Western Ontario
2oldman wrote: The easiest fix is to go to HD or Lowe's and get a flexible sink line. Then replace the pump's output line with it. The noise usually comes from the water hammer noise transferred to the coach's hard plumbing lines via the stiff output hose.
Yep, in our previous trailer I coiled 15 feet of high pressure vinyl tubing on the outbound side of the pump which does just than -- absorbs the pressure wave before it hits the hard PEX tubing. I also re-mounted the pump on some medium density foam (flattened water pipe insulation). Cost about 10 bucks.
edited 04/19/08 09:37pm by Garfie|d *
2001 Airstream Safari 25SS tugged by 2001 GMC Yukon 5.3L 3.73
Hensley Arrow • Jordan Ultima • Barker 3000 • Mckesh
