Griswolds-5
Santa Cruz
Hi -
We are considering a used TT (Trail light) and the Propane tanks sit inside the front of the trailer in a compartment between the master bed and the trailer hitch. I have noticed a lot of the newer trailers have free standing propane tanks on the outside.
Is one design better then the other?
Should we be concerned about having propane tanks in a confined compartment (especailly behind a wall next to master bed)?
Thanks
the wood tinker
Lake Elsinore, So. California
I think there are just covered by a plastic housing, mine are that way.
I had a Trail Lite Bantam but they were not covered on it.
2008 F250 SD 4.10 gears and HD towing package.
2008 299BHS Tango
Jerry & Sharon
Bindi & Cody....the furry kids
Griswolds-5
Santa Cruz
the wood tinker wrote: I think there are just covered by a plastic housing, mine are that way.
These are in a compartment, I have seen what your talkin about and these are not exposed in anyway...no cover, actually in a compartmentin the TT
chevyman2
missouri
Honostly I dont think it makes any difference. If you look at most any new Fifth Wheeler, you will see that they have 2 bottles locked up in a cabinet also. Similar to yours. I think it is strictly appearance only. I have found that tanks locked up in a cabinet are a bit harder to pull out to fill. Other than that, they will work the same. TIM
Tim-DW(Kathy)-DS(KEN)
04 AVEO-DD, 03 JEEP GRAND CHEROKEE, 94 Firebird(da toy)
07 COACHMEN SOA 32FKS(stress relief center)
If Im not at the CG---I'll be somewhere else!
Total nights camped in 07 = 62
Jim&Peg
Central Ohio
The enclosed compartments are required to be vented on the bottom. Propane is heavier than air so any leakage will escape out the bottom.
Cool Canuck
Winnipeg, MB, Canada
Griswolds-5 wrote: Should we be concerned about having propane tanks in a confined compartment (especailly behind a wall next to master bed)?
Thanks Take another look. I doubt that the compartment is confined. Usually the bottom is open and exposed to the elements. Most if not all 5th wheels have enclosed tanks under the bedroom.
00 Jayco Eagle 313 5th
01 F250 PSD S/C S/B
o2bpadln
Richlands, NC
Don't think it makes any difference. All 5th wheels are made that way.
o2bpadln
03 Chevy 1500 5.3 Towing Package
04 Rockwood 2602
Have road will travel. Have water will paddle.
rlc323
Illinois
Our Trail-Lite has the tanks inside the compartment. Keeps anyone from messing with your tanks and it has a more streamlined look. It is a bit rough lifting a full tank up over the bottom lip of the compartment. If you are not 6' 220 get a helper. The compartment is vented so no real safety issue. Also you may notice that the back wall of the compartment is well sealed from the interior of the trailer.
2002 Chevrolet Avalanche 1500 Z-71
2002 Trail Lite 8261
