RV.Net Open Roads Forum: Travel Trailers: Fuel Type
 > Fuel Type
thenkler
Goshen, NY
Posted: 04/20/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
I know that there have been some discussions about mileage and fuel costs but I wanted to start a discussion about the difference between regular and high-test and individual experience.
In a discussion with my regular mechanic he recommended using high-test when towing. The benefits would be better mileage and power when towing.
A 10% increase in mileage would more than pay for the higher cost with the added power as a benefit.
Anyone out there who has tested this?
2007 Jayco Feather LGT 30R
Yukon XL Denali
Me, DW, 5 Kids
irishguy101
Pennsylvania
Posted: 04/20/08 08:46am Link  |  Quote  |  Print  |  Notify Moderator
I don't know but I for one will give it a try.
With the Hemi its not recommended for fuel lower than 87 octane
* This post was edited 04/20/08 10:05am by irishguy101 *
Joe Dianne
and Spanky a Jack Russell
2004 Durango Limited w/Hemi
2005 Sunline T280 SR
targaboat
sulphur springs, tx, usa
Posted: 04/20/08 08:52am Link  |  Quote  |  Print  |  Notify Moderator
High test will result in improved performance IF the engine is tuned for its use which includes higher compression. Therefore, if your are going to retune your engine, which includes cam shaft, timing, and compression ratio and possible other items, then go for it. Otherwise, it is a complete waste of money.
Fly Boy
bluwtr49
Green Valley, AZ
Posted: 04/20/08 08:57am Link  |  Quote  |  Print  |  Notify Moderator
My Jeep HEMI calls for 89 octane but I usually run 87 when not pushing hard or towing. I have found that in some states (Utah comes to mind) all grades are not available and one time I filled up with 85 or 87 and the poor Jeep was very unhappy on the grades. I suspect the knock detector retarded the timing and the power loss was dramatic. Back to 89 and all was well.
However, with that said, I don't notice any improvement by going to premium over the 89.
Dick
2008 Toyota Tundra Crew Max Limited TRD
2009 Cougar 268 RLS ~8400 lbs road wt
Equal-i-zer 12,000 lb hitch, Prodigy BC.
2006 Jeep Liberty Turbo Diesel.....TV in Training
2005 Jeep GC 5.7 HEMI,(retired)
2005 Jayco Jay Feather 25Z, 4" lift (Retired)
SemperFiCop
Posted: 04/20/08 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Whatever the Owners Manual recommends...
Aloha Utah
Southwest Corner of Utah
Posted: 04/20/08 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Don't forget the effect of altitude. If you use 87 at sea level, you'll be fine with 85 at 4,000' or above. Out west 85 is pretty common because of the altitude and it's cheaper.
Me,DW & Max the Maltese
2005 Nissan Titan, Offroad Crewcab 4x4
FunFinder X-210
Lots of goodies
dave54
CA.
Posted: 04/20/08 11:54am Link  |  Quote  |  Print  |  Notify Moderator
I tow with premium if I know I will pulling grades or otherwise needing a bit more power.
I do not use premium for daily non-towing driving because the slight improvement in MPG (about 1/2 mpg) does not offset the higher cost ($0.20/gallon here).
I carry mid-range gas in my fuel cans because they are almost exclusively used for the generator and a bit higher octane is nicer to one cylinder 4 cycle engines.
Log off and go camping!
Kenneth
Washington, the state
Posted: 04/20/08 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Expect no great benefit using high octane gasoline in an engine designed for low octane gas. Expect no money savings using low octane gas in an engine designed for high octane.
A couple of years ago "Car & Driver" magazine tested several cars on a dynamometer. They found that using high octane gas in cars designed for low octane resulted on no gains big enough for their instruments to detect. Using low octane in an engine made for high octane caused no problems but burned more gas offsetting the cost savings. (Spark knock---ping, pre-ignition---is not caused by too low octane in modern engines. It is caused by carbon deposits glowing red hot and pre-igniting the fuel charge or by a failed control component. Some engines are made to have a harmless mild spark knock at high load.)
Modern engines with their computer controls can handle the designed octane level much better than engines in the pre-computer era. The 85 octane gas in the Rocky Mountain states is a hold over from the carburetor days when the thin air didn't need high octane gas. Modern engines run best at all altitudes with the gas they're designed to use.
Pete D
Washington
Posted: 04/20/08 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
What it really boils down to is that IF your car's computer can change the ignition timing to take advantage of the reduced knock of the higher octane fuel, then it might make a difference. Otherwise, it's a waste of money.
There is nothing in high octane fuel to make it more 'powerful' than low octane fuel, just more resistance to detonation/knock/pre-ignition than the lower-rated fuels. High and premium refer to the price, not the power of the fuel. It's the engine that makes the difference.
1998 Ranger 4.0 4x4
1991 Scamp 13'
 > Fuel Type
