RV.Net Open Roads Forum: TEXAS RT 105/US290 TO AUSTIN AND BEYOND
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > TEXAS RT 105/US290 TO AUSTIN AND BEYOND
ANCHORAWEIGH
South Carolina
Posted: 04/20/08 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone traveled RT 105/US290 from Conroe to Austin and continued west on US290? With tow I am about 60ft long.
Thanks in advance.
Chip N' Dale
Austin, TX
Posted: 04/20/08 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Have not towed on 105, but most all Texas highways are good you should have no trouble. 290 is a main route between Houston and Austin, so it is mostly at least four lane. Unless you just want to drive through the middle of Austin on IH35/290,I would suggest you turn on 21 at Paige and go to Bastrop. Then go into Austin via 71. 71 turns into 290 West when you cross under IH35. I tow a 35' 5er on 290 West all the time to Fredicksburg and Kerrville. Have driven 290 from Fredicksburg through Harper onto I-10 a couple of times and as best I can remember you should have no problem.
Since your name is Anchoraweigh, you might want to spend sometime in Fredicksburg. There is lots of shopping for the ladies and the Chester Nimitiz Museum of the Pacific War for the guys. IMHO, it is well worth visiting. The Lyndon B. Johnson Ranch and park is just east of Fredicksburg.
Hope this helped some.
CKAYAKER
Houston TX USA
Posted: 04/20/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
105 from Conroe to Brennan is a good road with passing lanes in the hills. Wild flowers are in full force now. Enjoy.
CKAYAKER
graywolf67
Houston TX
Posted: 04/21/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
What he said, done this same route alot in the past, Fredricksburg hsa a few good RV parks and well worth the visit, especially on Saturday's
Ford 2006 F150 4x4 5.4l 3V 3.73 rear
Zinger ZT260RL.
www.rv-forums.org
GizmosMom
Central Texas
Posted: 04/21/08 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Chip N' Dale wrote exactly what I was going to reply!
Marilyn w/ Joe, 2000 Xplorer Class B van, usually pulling a Ranger bass boat.
Smudge, (in photo) a Shih Tzu/Yorkie Mix and Gizmo is waiting at the Rainbow Bridge
n5lfh
NE Texas
Posted: 04/25/08 12:08am Link  |  Quote  |  Print  |  Notify Moderator
From Conroe to Navasota, 105 is fine. Narrows (less shoulder) from Navasota to Brenham. You will have it easier thru Austin, if you use 21 (West of Giddings) to Bastrop, then 71 to Austin. You rejoin 290 where 71 crosses under I35. 290 and I35 are the same road thru part of Austin. Much easier (and shorter) than approching Austin on 290 from the East.
Greg
2005 Silverado 3500 CC SRW
2003 Jayco Eagle 300FSS
Stagecoach
Decker Prairie, Texas
Posted: 04/25/08 07:36am Link  |  Quote  |  Print  |  Notify Moderator
If you go the 105 route make sure you turn right at SH 6 and follow it up to the next exit and turn left or else you will wind up somewhere else. 105 makes a big jog north that is not readily apparent there. Also as you approach Brenham on 105 take a left at the first Stop light as you approach Brenham. This road will take you to 290 and not through the heart of downtown (also past the Blue Bell Ice Cream Factory).
Dave, Beth and Katie
Marmalade, Aslan and Nara
2003 F-350 PSD CC 4.10 DRW 6.0L , Prodigy
2004 Mobile Suites 36 RE3 #1188
2005 PartiKraft Admiral PKA240 RE-4 Gate
2005 Lance 915
LoneStarRVing | Photo Gallery | My Blog
