RV.Net Open Roads Forum: Travel Trailers: back to factory
 > back to factory
mwebber78
New England
Posted: 04/21/08 05:27am Link  |  Quote  |  Print  |  Notify Moderator
Here's my guess - they are basically going to determine if the frame can be heated/bent back. If not the entire coach will likely come off the frame and it will be replaced.
Jayco has very FEW frame problems- likely due to NOT using Lippert for the frames. So take ease and cover yourself just in case with documentation.
However I feel like Jayco will treat you right and it will be corrected.
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Champion lil' yellow Chinese genset, 4000W
Camping Pictures
Btravelen
N. IL
Posted: 04/21/08 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Don't know about Jayco but we picked up our '00 Holiday Rambler last month from having the roof replaced at Monaco in Wakarusa, IN. The experience was great and they did a top notch repair. It was also cheaper than a local quote even though the shop rate was higher. Two ceiling panels that the local shop was going to replace from the inside (removing cabinets, etc) were accessable from the top when the roof was removed, thus saving time.
Good luck with your repair. I think you'll be pleased.
2000 Ford Excursion V10 (SOLD) 2005 Exc. 6.0L PSD, 2wd, 3.73LS, Air Lifts with Load Controller II, towing '00 31SKS Holiday Rambler Alumascape with a '01 Hensley.
JTCR
Central Mass
Posted: 04/21/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
My experience with Jayco and their factory repairs is that you should have them call you and have them tell you how they are going to repair your brand new trailer before they repair it. They did a lousy repair on my floor and I'M still fighting with them on the issue. Don't assume just because they are taking your trailer back to the factory to repair it that they will do the correct repair or replacement of your frame. I made that mistake when they took mine back to the factory to repair my soft floor. Good Luck
2004 GMC 1500 4x4 Extended cab short bed 5.3 3.73
2007.5 Jayco 328RLS
dyb
s.c.
Posted: 05/16/08 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Up date. my concerns were well founded it appears. Jayco is replacing our Eagle 320 rlds with another. There was a frame twist and also a box twist that was still there after the frame camber was corrected.
2005 F 250 5.4, 4.10 Gear, Tow/Haul, TorqShift Tranny 8ft. Box
Built in Break Controller
Super Duty super cab 158" wheel base
Eagle 320 rlds 2008
Raised Oct, 1988
Reese Dual Cam
jtslj
Salt Lake City UT
Posted: 05/16/08 06:56am Link  |  Quote  |  Print  |  Notify Moderator
glad to hear they are taking care of you.
I would test the slide a few times at the dealership before heading home with it.
1996 Chevrolet Suburban 2500 4x4 Vortec 5700
1987 Terry Tarus 29 R
trailer folks
iowa
Posted: 05/16/08 07:39am Link  |  Quote  |  Print  |  Notify Moderator
sure hearing alot of Jayco issues lately
 > back to factory
