AUcamper
florida
Okay, the water input to my toliet in my '06 Surveyor SV291 leaks. Leaks a good deal when water is first applied to the trailer. I do have a regulator on the water line. Its leaking somewhere around the fitting at the toliet. The problem is I don't have enough room to get my hand back there and really torque on the fitting. I think I'm going to have to pull the toliet out to be able to work on the durn thing.
Any suggestions? If I pull the toliet, do I need a seal when putting it back? Anything particular I should look for?
Also, I'm not sure if its under warranty, but the place I bought the trailer from is out of business and the next service place is to far a drive, especially for an issue like this. So I'm going to have to work on it?
Rumtan
Alberta
Local hardware store should sell the type of wrench thats used for sinks and toilets....its a 12" shaft with a alligator/pipe wrench end. Its mainly used by plummers.
2002 Palomino 22'
2002 Chev Silverado V8
Fish-O-holic
oldsffan
east coast
The wrench that Rumtan is talking about is called a basin wrench. You can get them at any hardware store.
edited 04/21/08 05:30pm by oldsffan *
Warped enough to power the Enterprise
AUcamper
florida
okay, but I have to take the toliet off in order to get to the fitting. Any insight on that? There's two bolts at the base so its probably like removing a home toliet. I'm just wondering if I need a seal or something when I go to put it back on.
BigPackFan
Endicott, NY USA
BPF
1998 TowLite 18TD
1999 Chevy Silverado
davidj54
South Alabama
There is a rubber seal between the toilet and piping so unless you tear it up it should go back without any issues. As yucky as it is I'd clean it good before re-installing it. To insure success and no downtime I'd buy one and just replace it.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
AUcamper
florida
yea, that won't work on the toliet. The toliet fitting doesn't go down, its 90 degrees out. THe toliet is up against a wall so there's not much room to get a hand, let alone a tool, in there.
I'll double check again tonight just to make sure, but I don't think that will work.
enblethen
Moses Lake, WA USA
It is probably the ball valve if it is a Thetford. The replacement valve comes with a new base flange gasket.
Bud
Suzuki XL7 pushing Pace Arrow
Rumtan
Alberta
Thanks Oldsffan and BigPackFan, thats the wrench I was thinking about but didnt know the name of. I have one and it sure saves the knuckles.
