RV.Net Open Roads Forum: Class C Motorhomes: onan gen
 > onan gen
digby
dayton ohio usa
Posted: 04/21/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
I talked to a gererator repairman and he advixed me to add 3 quarts of transmission fluid to the fuel tank when I refueled, said it was the best thing for keeping the engine clean from carbon and good for ghe gen too does anyone know if this is true
del lewis
2002 Infinity 32R
2000 Saturn L Toad
also 2002 Explorer Limited toad
Brake Buddy
MAJESTYPOINTERS
MONROE, MI.
Posted: 04/21/08 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know...I had the RV repair man (while he was doing the walk through)tell me to put one gallon of diesel in a full tank of gas in my gas MH once and a while for the same reasons. I have not had the nerve to try it yet. Let me know how it works out if you decide to doe it.
B-Plus
New England
Posted: 04/21/08 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard of people using Trans fluid for years, I have used Marvel Mystery Oil in the past but now I use Lucas Gas Treatment , it seems to be an oil based treatment. It won't hurt your engine to use Trans oil and it will clean the carbon up but I have never heard of putting that amount in before ( 3 Qt's ) seems excessive. Lucas gas treatment only calls for 3 oz for every 10 gals.
2003 6.0 Chev Trail-lite B-Plus 225
2007 6.0 Chev 170 Roadtrek ( Daily Driver )
1976 Corvette
Cool Mike
Mendocino. Calif.
Posted: 04/21/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
I just wonder what it would do to the catalytic converter, and even if the exhaust would smoke, the gal of diesel in a 50 gal tank, is like the 50 to 1 mix for a 2 cycle outboard motor, and they smoke.
2001 27' Four Winds Class-C E-450 V-10.
Buick Park Ave Ultra, Ford Ranger PU, JD 500 backhoe.
1941 Farm All "A"
melmar
Burleson, Tx
Posted: 04/21/08 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
There is no way I would add that amount of transmission fluid to the gas tank.
If any thing I would probably add Berrymans injector cleaner or something similiar that is specifically designed for that purpose. I think transmission fluid is a bad idea.
2004 Minnie 31C
2007 Honda CR-V Toad
2005 Nissan 350Z Toy
2 Mini Schnauzers, Ernie and Misty
Cool Mike
Mendocino. Calif.
Posted: 04/22/08 03:56am Link  |  Quote  |  Print  |  Notify Moderator
The OP doesnt say any different, so Ill assume hes talking about an RV generator that runs off the trucks 50g gas tank. I will add several 6oz bottles of injector cleaner per year to the trucks gas tank, the type that absorbs water, and cleanse the fuel system including the injectors.
And on a Ford with MPFI I can really notice a difference in how it runs, it idles smother, runs smother and has more power. And it may also have some effect on the small amount of this gas that the generator in the MH Burns, but carburetors dont get restricted as easily as fuel injectors, plus its not as easy to notice an improvement in its operation compared to the the trucks V-10 engine.
But if you put 4 to 6 bottles of the injector cleaner in the truck, then fill the tank, and do this once a year, both engines would run better.
I have taken a Ford service truck with 70K miles of cheap gas, and run 4 bottles of cleaner through it, and it really made an noticeable difference in how it ran, so now we do it to all the trucks. But not ATF or Diesel.
kopy kat
reno, nv
Posted: 04/22/08 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Hey Cool Mike...any particular brand of injector cleaner?? I ask because there are soooo many to choose from.
Larry
2006 Jayco 27DS---"Camp MiMiPaPa"
retired4fun2002
Bracey,VA,USA
Posted: 04/22/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
Like others, I have heard about Trans Fluid, but still like others - I will try other things first. I have been using Sea Foam and it has really worked well. I put it in a neighbors tank when he couldn't get his gen to stay online...cleared his carb up and saved a visit to RV Dealer. There is a another product (Deep Creep) which is same but in a spray version that I've used on mowers, and small engines - great results.
Chlirod
Fort Worth, Texas
Posted: 04/22/08 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Personally, I swear by Marvel ystery Oil. I use it on my motorcycles as well and once had a mechanic mention after rejetting the carbs on one of my H-Ds that the fuel system was exceptionally clean. No proof- but I attribute to MMO.
We used to pour tanny fluid straight into the carbs of normally aspirated cars with the notion is cleaned the system. Funny though, we never once thought about adding it to the gas tank. Might be worth a try - for someone other than me.
midnightsadie
ohio
Posted: 04/25/08 05:29am Link  |  Quote  |  Print  |  Notify Moderator
tranny fluid/diesel fuel are old tales from the past ,yes they did work back in the old days ,but I never put it in the new injected motors , I use seafoam or berrymens . both are good products . I:VE seen the sea foam eat up laquered up old gas . stick with the new products on the market.
 > onan gen
