RV.Net Open Roads Forum: Tech Issues: trailer power at home help
 > trailer power at home help
StillOnThePot
California
Posted: 04/21/08 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
I want to install an outlet at home that will give me power for the trailer at home. I have been reading about this for a little bit and now slowly understanding it.
I bought my house the the previous owner had a 240 outlet in the garage for a kiln. I have not examined the outlet bu someone please clarify this for me:
If it is a 50 amp 120/240 outlet and is hot, can i just use a 50 amp tp 30 amp reducer plug the trailer straight into this? I am afraid to try but i may check the volts using a voltreader with this instructions (http://www.myrv.us/electric/).
that will give me the voltage, but how can i be sure of the amperage?
thanks for the help in advance
LarryJM
NoVa
Posted: 04/21/08 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Check the breakers in your service panel since they should be labeled and might give you a start.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
mexfishguide
arkansas
Yes, you can.
The outlet is more then likely 50a / 220v. Which is what you would have at a campground, so the adaptor will work fine.
Take Care
Mexfishguide
wayne_tw
South Dakota/Georgia
Posted: 04/21/08 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
If it ran a kiln and is 240 volts, then it has enough amperage for the RV. However, it sounds like you do not have the knowledge to experiment with electricity and to understand what is needed for your RV. PLEASE get someone who does. I am not slamming you- its OK not to understand electricity- its too big a risk of personal injury and property damage.
hemlox
Western Illinois
Posted: 04/21/08 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe I'm confused, but my rig runs on 30amp 110 volt. I'm thinking the 220 volt will fry his rig. Am I wrong in thinking this?
25 ft. Gulfstream Conquest
Chevrolet Suburban 4x4
Reese Dual Cam WD Hitch
Prodigy Brake Controller
grizzlygiant
Coeur d'Alene, North Idaho, USA
Posted: 04/21/08 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
VERY GOOD ADVICE!!!
North Idaho
2008 Heartland Big Horn 3400RL fifth wheel
2007 Dodge Ram 2500 4x4 5.9 Cummins
StillOnThePot
California
Posted: 04/21/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for the quick replies, guys.
wayne, it's not the knowledge, it's the experience/confidence that i don't got i just like to triple check my options before i move foward (especially with electricity)
i just wanted to get some quick feedback from some of ys'll just to make sure that i may already have the outlet and not do more work then i need to.
so, to check it does this sound right to ya'll?
A TRUE 50-amp Service is 120/240 Volt. In this Service the HOT leads (X & Y) come from L1 and L2 so when you check it the voltage between X and Y should be 240-Volt, X and W 120-Volt, Y and W 120-Volt, W and G 0-Volt. This service provides 12,000 watts
thanks again.
enblethen
Moses Lake, WA USA
Posted: 04/21/08 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Stillonthepot:
Your last paragraph is correct.
Before you plug your rig in through the 50/30 adapter get a plug in tester to check for polarity. It will also smoke if it is wired in-correctly. Or use a volt-ohm-meter.
Bud
Suzuki XL7 pushing Pace Arrow
Chuck&Gail
In the Colorado Mountains
Posted: 04/21/08 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you have it. Just remember that your 30 amp TT is NOT 240 VAC anywhere, so you only use ONE of the hot leads. Easy to check at adapter BEFORE plugging into TT.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
George H
Washington
Posted: 04/21/08 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Hemlox, The male plug is configured to pick up only 120 volts.
George, Juanita and Mandie (boss Shar-Pei)
01 F350, PSD, DRW
05 Carri-Lite 32RS3
