keith_parker
meansville, georgia
i have a 1993 layton trailer that i just purchased. the folks i bought it from SAID it didnt leak. was they ever wrong. i am having to replace the epdm membrane. my question is can i replace the the white on black with the black and if so what problems will i run into down the road.?
thanks
keith
JJBIRISH
Butler, PA, USA
I don't know the answer to your question, but guess one thing would be excessive heat build up inside the trailer... these things aren't insulated like a house and they don't have a ventilated roof, that with the fast heat change could cause a condensation problem... but again I am guessing...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
enblethen
Moses Lake, WA USA
I would recommend the Brit-Tek.
Try going to Dicor website for better info.
Black roof would be bad.
Bud
Suzuki XL7 pushing Pace Arrow
Bumpyroad
Virginia
check out previous threads about using LineX or similar. I wouldn't put black up there in ga or anyplace south of alaska.
bumpy
keith_parker
meansville, georgia
its keith again thanks for all your input but no one has given me a reason why except one and that has been with the heat. what damage am i looking at if i use black insted of white.
Bumpyroad
Virginia
keith_parker wrote: its keith again thanks for all your input but no one has given me a reason why except one and that has been with the heat. what damage am i looking at if i use black insted of white.
wait a minute. you are from Georgia right? you plan on using this in the summer right? do you use air conditioning and want it sort of cool in your RV? It will be a virtual oven inside with a black roof. but that's JMHO. how many reasons do you need?
bumpy
Redaman
Anaheim, Ca
A few years ago I had my 5th wheel roof sprayed with a gray rhino coat and it's been great. We haven't noticed much of a temperature change, but we don't spend a LOT of time in our trailer anyway....and that's what we have Air Conditioning for.
Damage wise, I think black will make it pretty hot inside. Other than that, it will never come off, but you will still have to seal around the vents etc, with silicone.
Tom & Diane
Sunny Southern California
2003 Chevy Duramax/Allison Extended Cab
Reese 16K slider
94 Prowler 27 5J w/slide
