RV.Net Open Roads Forum: Truck Campers: Potentially weak point in truck bed
 > Potentially weak point in truck bed
snowranger
sf
Posted: 04/22/08 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
silversand wrote:
...I hope you don't mind, I've added my thoughts to your photo as annotations:
I appears to me that you have a disproportionate load sitting on too little bed real estate?
If this proves to be the case, spreading the load out using a bed mat would be crucial to solving it. Additionally, I think that those stress fractures need to be reinforced somehow...
Good luck,
Silver-
Thanks for the markup. What kind of reinforcement would work though? Any welders out there?
Jeff3161
Pasco,Washington
Posted: 04/22/08 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Gone are the days of GOOD American sheetmetal.
TonysDodge
AZ
Posted: 04/22/08 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Before welding it, I'd get a bed mat and maybe some plywood, like someone else had mentioned. See if it gets worse. If it doesn't get worse, then I'd weld it and use the mat+plywood. It may be that the bed is just a little higher in that area.
Tony
2006 Dodge 3500 QC LB DRW CTD
2006 Jetta TDI
1996 Passat TDI
2003 Lance 1025
snowranger
sf
Posted: 04/22/08 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Tony
What if it gets worse?
JoeChiOhki
Keizer, Oregon
Posted: 04/22/08 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Then you need to build a platform that fills in the recesses between the raised areas of the bed so that ALL of the bed is bearing load instead of just a few corners.
If that doesn't fix it, you may need to lift the bed and build a tube frame to reinforce the underside of the truck bed where the load is distorting it.
CB Channel 17 Space Ghost
'1991.5 Dodge W-250 Power Wagon - Club Cab Long Bed V8 5.9L 4spd H.D Auto 4x4 4.10 Gears
'1987 Pullman Mini Camper
'2004 Bi-Mart 4x8 Cargo Trailer
snowranger
sf
Posted: 04/22/08 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Okay, thanks for the plan B. I may have to gain some metal working skills.
TonysDodge
AZ
Posted: 04/22/08 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
That's the fun part!
Keep us up to date on your progress.
Tony
nwcamperguy
Washington
Posted: 04/24/08 02:54am Link  |  Quote  |  Print  |  Notify Moderator
After reading this forum, I went out and found a weak spot in my truck as well. I immediatly went to my local farm store and bought a horse stall mat. Very thick and fairly inexpensive. Hope it helps. Thanks guys.
trails2004
Wyoming
Posted: 04/24/08 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Add some horizontal 2x12's to bottom of your camper- to help distribute the weight AND provide a stable and flat base
2002 Dodge Ram 2500 SLT 4x4-AFE Cold Air,4"Exhaust,Toyos,Ranchos,Dual Air III- Firestones 2004 Hallmark Cuchara XL 9.5 w/Carbon Fiber Roof, WFCO 9845,Xantrex XBM,Honda 2000,1997 Grumman GV19TC- Crew Wifey,(Odin,Bridger & Sam,Wirehairs)
silversand
Montreal
Posted: 04/24/08 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Snow:
A quick question: does your camper have a rail or edging fastened around the entire perimeter of your camper tub edge, that protrudes down below the flat camper underbelly?
S-
Silver
