RV.Net Open Roads Forum: Fifth-Wheels: Valve Stems Cracking on new 5ers
 > Valve Stems Cracking on new 5ers
5wildcat
Sanford, NC
Posted: 04/22/08 04:09am Link  |  Quote  |  Print  |  Notify Moderator
Just curious if there are any other RV manufactuers that are having issues with valve stems cracking when the RV is less than 1 year old? I know Wildcats by Forest River are having a lot of issues with this.
2004 F-250 FX4 CC PSD, P3 Brake Controller, Valley Hitch w/ slide
2007 Wildcat 32QBBS, 1 1/2 bath
skip298
South Bruce Peninsula Ontario Canada
Posted: 04/22/08 04:41am Link  |  Quote  |  Print  |  Notify Moderator
I cannot say about the trailers, but I can say about the valve stems...I have had 3 or 4 on my car wheels go bad..two of which resulted in tires that went flat while on the road......they were installed when the tires where installed and were only a couple years old,I bought all at Wally Mart .......it appears that quality production materials were not used.......it would be interesting to find out if they were manufactured in China......If the tires came from China I would bet the stems did too......
Buck 10
Cumming Ga.
Posted: 04/22/08 05:31am Link  |  Quote  |  Print  |  Notify Moderator
I have already replaced the valve stems on our 07 Wildcat same problem. You may want to look at steal stems.
Bluhorn
North Carolina
Posted: 04/22/08 05:46am Link  |  Quote  |  Print  |  Notify Moderator
i have had the same issues with my Wildcat and replaced the stems with high pressure metal ones.I do not think it is one manufacturer that has a problem. A few of my friends with Rv's of other manufacturers have had similar issues.Probably made in China.I am also convinced that a lot of tire blowouts that we read about on these forums are due to these bad stems.
2007 Dodge Ram 2500 Quad Cab 4X4 Auto 5.9 CTD
2006 Wildcat 28RK Fifth Wheel
16K Husky Slider
Tvov
CT
Posted: 04/22/08 06:01am Link  |  Quote  |  Print  |  Notify Moderator
This is the first I've ever heard of "bad" valve stems. I do know to check the air valve thingy in the stem when I replace tires, I have a couple little stem tightener tools laying around to make sure the inside of the stems are tight. Almost all of my "tire work" is done by a local garage, they know me and do excellent, dependable work. Tires are the ONLY thing keeping you on the road, so make sure you have the work done by someone you trust.
2008 F-250 CrewCab 5.4L,
Bluhorn
North Carolina
Posted: 04/22/08 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Tvov,the stems seem to be cracking around the base.You would not see it unless you got down and actually bent the stem over. Seems to look like old age rotting of the rubber.My brand new, never used, covered spare tire stem was the same way.
Delaine and Lindy
Linden Tn. (The View)
Posted: 04/22/08 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I don't run rubber valve stems on any of my tires. I run metal stems on all Truck and 5th wheel, Car Hauler and Gooseneck Trailers. I also run the Pressure Pro monitoring system on all Trailers and Truck. China has a serious problem with Tires and probably valve stems also? The RV industry are still buying the China Bombs is unbelieveable. I also have Mission and Freestar on Car hauler and the Gooseneck. But will not run anything but the Goodyear 614's on the 5th wheel. I believe you must run the pressure on the side walls of the China made tires. For some reason they seem to heat up when the pressure is the least bit low. GBY...
2008 Chevy Silverado LTZ 3500, DRW
2008 Chevy Equinox LTZ
2009 Mobile Suites 36TK 3
B&W Hitch
www.webspawner.com/users/lnhdch
We are Blessed !!!!!!
EPenney
Galt, Ca
Posted: 04/22/08 07:22am Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem with cracked valve stems on my 5er wheels. In fact, one stem completely blew apart. Lucky it did so while parked at the storage lot.
According to the tech at Les Schwab, there was a big lot of valve stems from China that were bad, and showed up in the US during 2006 & 2007. If your 5er was made during the second half of 2006 thru the first half of 2007, check those stems. My 5er was made in Jan. '07.
'07 Chevy 2500HD Silverado "Classic" CC D/A 4x4
'07 Komfort Trailblazer T252FS fifth wheel
Reese Signature 18K Slider and other stuff.....some useful.....some not
marvmarcy
Polson, MT, USA
Posted: 04/22/08 07:48am Link  |  Quote  |  Print  |  Notify Moderator
My fiver had steel stems on it when I bought it but it also had stem extenders. The extenders leaked enough to cause problems, so off they came. I highly recommend replacing the rubber stems with steel ones at the next tire change, if not sooner, and not using any valve stem extenders (especially with a TPMS).
In the past year I started looking at where things are made and refusing to buy anything made in China.
JMHO
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
BB_TX
McKinney, Texas
Posted: 04/22/08 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Keystone issued a recall on rubber "pop-in" valve stems on their steel wheels on some '07 models, Montana, Challenger, Everest, etc due to leakeage. Aluminum wheels were not affected. My 4 on the ground are aluminum, but they replaced the one on my steel spare for free.
