RV.Net Open Roads Forum: Technology Corner: Question about Dish Network switch.
 > Question about Dish Network switch.
SWMO
Southwest Missouri
Posted: 04/25/08 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
SW21 and SW42 ARE NOT external switches.
My 21 is and its the switch that allows one cable from the LNB's.
2002 Ford F350 Crew, LB, DRW, 7.3L
Jayco Designer 34RLQS
acker1
fulltimer
Posted: 04/25/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
My SW21 is external also.
DICK
37'--'98 Endeavor
toad--'05 Crewcab GMC
Viet Vet '65, Ia Drang Valley survivor (We Were Soldiers)
Elks
www.4ezdaz.com Same site, different URL
dougrainer
Carrolton
Posted: 04/25/08 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
DICK
You are correct, but my post was related to the Dome systems on RV's. The Dome systems that allow switching between 2 or 3 sats have to utilize the SWITCH 21 internal that the Dish receivers have. When you have a home type system that has the external Switch 21, the receiver must do the CHECK SWITCH to set up the INTERNAL Switch 21. If you do not do that, then your external will not function. Doug
