RV.Net Open Roads Forum: Tow Vehicles: TOWING WITH MY 2500 SUBURBAN
Search only in Tow Vehicles
 > TOWING WITH MY 2500 SUBURBAN
TRLTU
MICHIGAN
Posted: 04/22/08 11:42am Link  |  Quote  |  Print  |  Notify Moderator
I HAVE JUST PURCHASED A 2008 JAYCO 32BHDS (7800 LB DRY) AND PLAN ON PULLING IT WITH MY 2006 CHEVY SUBURBAN 2500 LT AUTORIDE (6.0 LITER WITH 4:10 REAR END). I AM CONCERNED WITH MY TRUCK PULLING THIS HEAVY OF A TRAILER. DOES ANYONE HAVE ANY EXPERIANCE OR COMMENTS TO HELP ME EASE MY MIND OR SHOULD I LOOK INTO ANOTHER TRUCK. PLEASE NOTE THAT THE WIFE USES IT AS A DAY TO DAY TRUCK TO HULL THE KIDS AROUND.
THANKS
rhondavid
Birmingham, Al
Posted: 04/22/08 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
First, please turn off the caps lock as it implies you are yelling and makes it very hard to read.
No to address your question. You will be in great shape with the 2500 Suburban. The towing capacity of the Sub is more than sufficient and the 6 liter engine is very stout. The 8.1 engine would have been even better but you will not have any issues.
I have had three Suburbans and as looking at the 2500 Suburbans and was encountering problems finding one at a reasonable price. I did a lot of research and no one had any negative feedback on the 2500 Suburbans with either engine.
Congratulations on your new Jayco. We love ours and if we decide to get another TT it will be a Jayco as well. You will be more than pleased with your rig.
David,Wife,4 kids,SIL,1 grandchild
2003 Ford Excursion Eddie Bauer 7.3 PSD w/3.73 rear end
Jayco Kiwi Too 30T bunkhouse w/triple bunks
Prodigy Controller
Reese Dual Cam HP
Michelin LTX M/S
Topsail Hill Cult Member
8.1 Van
Millstone NJ
Posted: 04/22/08 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
It will pull it but like he said the 8.1 big block would pull that TT very easy.
FKA PSDExcursion
2002 Chevy Express LS 3500 8.1 155" WB passenger van 3.73 posi (GT4/G80)
41 Ft 2003 Thor Citation 41-ZBSR TT w/ Hensley Arrow
TRLTU
MICHIGAN
Posted: 04/22/08 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry for the caps! I am an architect and all my noting is done in caps. bad habit! Would you recomend any load leveling air bags or do you think they are not necessary?
JustLabs
Washington State
Posted: 04/22/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt you'll need air bags. 7800 dry is about 9500 wet. That means you'll have about 1000lbs of tongue weight.
With the right W/D set up it should be no problem for a 3/4 ton Burb.
2007 Dodge Ram 3500 SRW,4x4,Cummins 5.9, 6spd.
2007 Keystone Cougar 289BHS Fifth Wheel.
Camping Hoosiers
Southern Indiana
Posted: 04/22/08 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Suspension wise you will be fine. You may want a little more power than the 6.0 will give you but as long as you are not in a hurry you should be fine.
2006 Jayco Eagle 314 BHDS
2003 Suburban K2500 LT 8.1 V8
KYANNA BIRDS - Jayco Flight # 14
BurbMan
Long Island, NY
Posted: 04/22/08 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Biggest problem with SUVs is that you run out of payload before you hit the tow rating. I'll bet he's only 9000 or so wet, but that will be plenty.
Truck is 6500 lbs empty, plus 1000 lbs tongue weight, plus 900 lbs passengers = 8600 GVWR. It's worse with the Excursion because of the high empty weight.
8600 GVWR plus 8000 trailer (9000-1000 on the tongue) = 16,600 GCW against 17,000 GCWR.
It will pull it, but you'll be wishing you had the 8.1.
Lucas874
Kingston, NH
Posted: 04/22/08 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Your truck will do it but you'll feel the trailer behind you, especially in the hills. Nice trailer! I can see myself in one in another year or so...
2007 Jayco Jayflight 29BHS
2002 Chevy Silverado 2500HD
Lantley
Ellicott City, Maryland
Posted: 04/22/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
You'll be OK but your tongue weight will be over 1000 lbs closer to 1200lbs. Suspension wise you'll be fine. The 6.0 gasser will be adequate. A 8.1 would be a a better fit. Since you already have the 6.0 give it a try. Overall the 2500 Burb will be able to handle the TT without any safety issues. If you feel the need for more power you can always upgrade to a Big Block later.
01 PSD X,06 Trailvision 31BHDS Edge Evolution
4"exhaust,AFE,C-Betr,Tornado
Firestone air bags,TomTom,Atwood 3500
Hensley,Prodigy,exhaust brake,Swift Hitch
14'PortaBote9.9hp,6"PVC,Thule,Combi-Cam
Toppoprails,Bodiak,Sherline,Maxx Air
Subaru 4300is w/Gen Box
Roadhouse66
Sanford, MI
Posted: 04/22/08 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
He has the autoride....doesn't that already have factory Airbags in the rear? If it works like the air suspension did in my old Expedition it will fill the airbags manually to raise the rear of the truck up hooked to a heavy trailer. So in otherwords no need for aftermarket air bags.
Yes a 8.1L would be better, but you wont find it in a new Suburban. I doubt this gentleman wants to get rid of his new 2008 'Burban for a used '06 or older.
'07 Hornet 30BHS TT-family cabin
'94 Suburban 2500 tow rig w/454ci, 4.10 gears, Prodigy controller
'95 Jeep Grand Cherokee-8"lift, 37" tires-play toy
