hasheel
Durham,NC
Anyone had to drill a hole in the firewall to install the breakaway switch?
2008 Tioga Ranger 31 W
02 Suzuki XL-7 toad
BrakeBuddy
tommy wilson
southern ca, usa
i found it was easier to drill holes in the floor for brake buddy wiring in my 2005 malibu maxx.
tommy wilson
1996 kountrystar dp
spartan mountainmaster chassis
Troubleshooter
Anchorage, AK
I find that a 'stepped' drill works wonders when it comes time to drill a hole for wires, switches, or the like.
Just make sure that both sides of the area you are planning on drilling is free of any obstructions.
The nice thing about the 'stepped' drill bit is that is starts off drilling a small pilot hole, and then enlarges the hole in set diameters.
Only One Old Fellow's Opinion
Bill
2002 Discovery 3126E CAT
2004 Saturn VUE
Mountain Master Tow Brake
Musicman
Wenatchee, WA
I drilled up or down through the "rocker panel" beneath the drivers side door. I removed the finishing panel, and brought the wire up under it and it stays coiled up under the drivers seat. when not in use. No hole in the firewall.
Musicman
FMCA #F333309
'97 Winnebago Vectra
'01 Blazer LT
rmmpe
Milford, PA
Generally speaking, there is already a hole in the firewall, which is how the wires are routed from the engine compartment to the interior.
Look for the run and make a hole in the plastic "Grommet" to route the wires you want to run.
Do not simply route wires through a rough hole through metal. The wires will chafe and you may have some serious problems.
If you must remove the battery to access the hole, I suggest you attach a small battery charger to the terminals, which will keep power to the electronics, avoiding reprogramming. You can also use a lighter plug in an unswitched power port. Be careful with this because reverse polarity can damage something.
Roads Scholar
Carry on, regardless
Alpine 36SDS
Cummins 330 ISC
Allison 3060
Johng
Gilbert, AZ, USA
Agree with mmpe, there should be a rubber or plastic gromment that the steering or wires run through can easily be accessed. That's the way mine was done.
Happy RVing
John and Judy
US Air Force - Retired
05 Beaver Santiam 40DST
08 Malibu Toad/Brake Buddy
rvten
Crossville,TN
Even the car dealer did not want to drill into the firewall on our G-6.
Looks like all the wireing is out of the way behind the dash not under it with gromets.
right now I just run wires for BB and lights through the door and engine hood when towing.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008
Class C passed Class A owner
Pontiac G6
There is NO such Thing as a B+
