RV.Net Open Roads Forum: If camper doesnt have grey water tank were does it go??
 > If camper doesnt have grey water tank were does it go??
qwerty11
Posted: 04/22/08 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
If it doesnt have a tank where does the water go when you use the sink???
2manytoyz
Central FL
Posted: 04/22/08 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
In the two Class B's, and two Popups I've owned, it drained on the ground. The Coleman Popup did have a threaded outlet underneath, so it was possible to connect a hose to a portable tank.
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
CObronco
Colorado
Posted: 04/22/08 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
On the underside of our camper there is a spot for us to connect a hose that then is put into a water jug outside the camper on the ground. We dump the water then when we get home.
Me
DH
DS
One camper, one boat, one baby = one happy camping family!
MAJESTYPOINTERS
MONROE, MI.
What year is your RV...some early rv only had one "black" holding tank and all waste water went into one single waste tank..Do you have any holding tanks at all???
Sportsman Matt
Blackstone, MA
Posted: 04/22/08 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
A couple of options. I have a green hose and hose connection I use to divert the waste water away, and I dig a small cathole and put the end of the hose in there and let it soak into the ground, unless prohibited, then I just hook the hose up to a collapsable greywater container and dump when available. Some places frown on the cathole idea, and others actually encourage it. Of course the key to the cathole is to dig it about 6" in diameter and 6 to 10" deep, then when done, cover it up with the displaced earth so no one knows it was there. Also it tends not to stink up the campground by doing that, as for just letting it run out the end onto the ground, that could cause some real smelly spots in the campsite
Good Luck
matt
Life is short, Play harder.
2002 GMC Sierra 1500 Regular Cab Long Bed 4.3L V6 Automatic 2WD
1989 Sunline C-750 Slide In Truck Camper
7'6" Floor, 11'6" OAL
Fishing and Hunting New England and eventually the world
Jeff3161
Pasco,Washington
Posted: 04/22/08 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Good Luck
matt
Ok I have no real problem with that pratice a little grey water shouldn't be too harmful. But let's just say this is a popular camping spot that gets used everyday with maybe one day of rest per week. If everyone did this you could end up with several muddy cat holes.
Paoli
Quesnel BC
Posted: 04/22/08 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
According to Al Gore's new film "An Inconvenient Truth," we're in for "a planetary emergency": melting ice sheets, huge increases in sea levels, more and stronger hurricanes, and invasions of tropical disease.
And now we can add little muddy holes at camping spots. When will it end? :-)
JoeChiOhki
Keizer, Oregon
Posted: 04/22/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Depending on the camper, its age and design it could be one of the following:
1.) Combined Waste tank - Black and Grey go to the same tank
2.) Combined Waste Tank w/ Diverter Valve - Black and Grey can both go in, or the black can be piped off seperatly leaving the tank for black only (This is the configuration my camper has).
3.) Grey Water run-off - Similar to combined, but no way to direct grey into tank, only runs off seperately. (Had another KIT that used this method prior to it being sold due to the truck being too underrated for the load).
Hope this helps
P.S. I also have a seperate grey tank I added to my cargo trailer and a little pump system that helps overcome the change in height between the camper being off the truck and the tank up in the trailer, or the trailer being higher than the truck, etc... etc...
When I can, I will do the cathole method as well.
CB Channel 17 Space Ghost
'1991.5 Dodge W-250 Power Wagon - Club Cab Long Bed V8 5.9L 4spd H.D Auto 4x4 4.10 Gears
'1987 Pullman Mini Camper
'2004 Bi-Mart 4x8 Cargo Trailer
jimandsue60
North America
Posted: 04/22/08 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
It goes on the ground like all the tent campers do.
Jim
2007 Winnebago Vectra 40TD, 2006 Mini Cooper S, 2003 Chevy S-10 4x4 ZR2, Four Wheel Camper Eagle, 2008 Polaris Rzr click here to see our adventures
Picture Page
Our Location User # 1979
Our Videos
JimBollman
Upstate NY
Posted: 04/22/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Using a 90 degree hose adapter I routed a hose from the output connection along the inside edge of the bed of the truck to the back corner behind the wheel well and into a 5 gallon soft side jug. I have access through a door on the inside for trips long enough that I need to dump it before we get home. In the past I routed it into a pail or container tucked under the edge of the truck but it was always a pain when we were in travel mode. The last outside tank I last used was a drain pain like they use to change oil it has a bowl area that drains in to a hole in the center. When it was getting full I could screw in the plug and carry to an appropriate place to dump. I would strap it to the back of the camper when we were traveling. It was nice because it was thin enough to easily slide under the truck. I found that the tractor supply type places had bigger drain pan tanks, the one I have holds 5+ gallons.
Jim...
