RV.Net Open Roads Forum: Class A Motorhomes: Spark Plug recommendation?
 > Spark Plug recommendation?
kplender
Denver
Posted: 04/23/08 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
I am installing the BANKS headers/exhaust system on my 1997 F-53 with 460 this saturday (removed the old system last Saturday). I figure while I'm in there I might as well replace the spark plugs. Any recommendations on brand/part number? Thanks in advance!!
1997 Bounder 36S on F53 Chassis
1992 Geo Metro Toad
wshrman
Orange, Ca.
Posted: 04/23/08 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
I just changed my plugs. Champion has a mfg rebate of up to $2.50 per plug good thru the end of May.
2000 Rexhall Roseair 3450 V10, GearVendor, AutoFormer
2001 Ranger, Remco, BRAKEbuddy
Belgian Sheepdogs, Blazer & Chayna
Shareholder Pismo Coast Village
KOG
Winterville GA
Posted: 04/23/08 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
Bosch Platinums are excellent plugs with a wider heat range than most and lower firing voltage than standard plugs.
Daveinet
il
Posted: 04/23/08 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
I proved a mileage improvement with Splitfires on a an Pontiac Transport. MPG averaged over the first 20K miles from brand new. Next 5K miles after installing Splitfires increased my average mileage from 19.5 to 21 mpg. I have no documentation on the motorhome as I put Splitfires in it the first day I bought it. In every other vehicle I have installed Splitfires, I have noticed smoother idle and emissions testing always was below the measurable limit. The butt meter can tell a very subtle improvement in high gear roll on.
I don't believe that one really gets a two forked spark as advertised, but I do believe that because the electrode is off to either side, there is better exposer to the fuel charge.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
bill h
el segundo
Posted: 04/23/08 11:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have a car that needs new Bosch platinums to pass CA smog.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
John&Joey
Northern MN
(Baby it's cold outside)
Posted: 04/24/08 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
From my snowmobiling days, I learned to use NGK's. They would never fowl out, and would always start no matter what the temperature. The guys that used champions, well.........
