RV.Net Open Roads Forum: Travel Trailers: Can't Find Cable Connection
 > Can't Find Cable Connection
carlstone05
Bellevue, NE
Posted: 04/23/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Ok...I am either blind, an idiot, or there just isn't a cable connection on my trailer. I have a 2008 Cherokee GreyWolf 26 BH travel trailer. I have a cable connection inside my trailer, which I assume connects to both the antenna and then somewhere to plug-in site cable. The problem is I have looked high, low, on top and underneath and can't find anything. It was marked on my old coachmen. For whatever reason I don't recall it being identified on the walk-through when I picked it up.
Anyone with some insight please speak up!
Thanks
Carlstone
2005 Suburban 1500 2WD, 5.3L, 4.10
Prodigy Brake Control
Equal-i-zer Sway/Weight Distribution
2008 Cherokee Grey Wolf 26BH, Patriot Edition II
skipnchar
Topeka Kansas USA
Posted: 04/23/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
they are often close to the power cord on the trailer.
abe1759ca
Van. B.C., Canada
Posted: 04/23/08 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
look for a cover the same as your electrical plugins have it should have your cable hookup and phone hookup. mine is on driver side of 5vr. hope this helps
abe.
Yeldarb
Omaha, Nebraska
Posted: 04/23/08 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
There isn't one sorry. I have the grey wolf 28BH (your campers brother) and mine is the same, the internal cable outlet is only for the antenna. Something you'll have to add on if you want. I plan to sometime but no big hurry. AC Nelson is your dealer correct?
Thanks
Bc
Brad('67) and Valerie('68) Clements
Alyssa('95)
Samson and Toby
2008 Cherokee Grey Wolf 28BH
(NEW) 2005 Ford F350 SD Crew Cab Dually 6.8L V10
(OLD) 1999 Chevy Silverado 5.3 3.73 1500 Z71
Omaha, Nebraska
Camping Nights in 2008 - 31
Our Camping Adventures
mehwwh
Thanks
Carlstone
Check with the dealer from whom you purchased your RV.
'03 Silverado 1500, Ext.Cab, Z71 Off Road, 4X4, 5.3L, 3.73 rear, AutoMeter Trans Temp Gauge, Putnam Class IV
'08 Jayco JayFlight G2 23FB, Reese WD Hitch, HP Dual Cam Sway, 800# Trunnion Bars, Barker 3000# Power Tongue Jack
luck would have it
Dimondale (Lansing), MI
Posted: 04/24/08 01:22am Link  |  Quote  |  Print  |  Notify Moderator
chances are, if you don't see it than it's not there. We had a 23' HTT that had it and out 27' TT does not....go figure! we use the flat coax cable and slide it through the window.
Dave.
2004 Chevy Silverado Z71, Ext. Cab 5.3L
Prodigy Brake Controller
Husky WD Hitch
Dual Cam Sway Control
2007 27' Salem BHBS (Bunk Slide/Super Slide)
Bucky Badger
Madison, WI
Posted: 04/24/08 05:25am Link  |  Quote  |  Print  |  Notify Moderator
Most of the time cable outlets are an option.
Fred & Jodie, dogs, Zoey & Bella
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
Member Titantalk.com
Nights camping 08 (43)
Rallies/Gatherings
IL
WI
shenandoahvalley
Shenandoah Valley, Virginia
Posted: 04/24/08 05:50am Link  |  Quote  |  Print  |  Notify Moderator
We have a Gulfstream and ours was on the curb side under the dinette window so you have to run the cable under the trailer to hook up. Per the factory it was done that way so you can use a splitter and hook up a tv outside. Seems like a cheap fix to me.
carlstone05
Bellevue, NE
Posted: 04/24/08 05:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Bc
Yes, AC Nelson is my dealer. I was going to call them and ask about it today. Why on earth would they not put the cable connection on?
mockturtle
Northwest
Posted: 04/24/08 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Ours is on the passenger side of the trailer and is covered with a small, plastic cap.
Husband: Derek
Dog: Bucky
RV: 2000 Aerolite 19RB TT
TV: 1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
