RV.Net Open Roads Forum: Travel Trailers: Wayne's rv stabilizer
 > Wayne's rv stabilizer
tkeaton
Indiana
Posted: 04/24/08 04:25am Link  |  Quote  |  Print  |  Notify Moderator
Anyone use Wayne's rv stabilizers? Is two enough? It definitely seems like a good and less expensive alternative to some of the other stabilizing systems. Thanks
Tvov
CT
Posted: 04/24/08 04:31am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a link or more description of what it is?
Just found the site. Looks interesting...
http://www.waynesrvstabilizer.com/
2008 F-250 CrewCab 5.4L,
swebber
Brunswick , MD
Posted: 04/24/08 04:46am Link  |  Quote  |  Print  |  Notify Moderator
I have the Wayne's Stabilizer that I use on our TT. It does minimize the "wiggle" movement of the trailer.
I bought ours on clearance at a local Wal-Mart for around $20. It sat on their shelf for almost a year.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
dup4fun
NY
Posted: 04/24/08 05:18am Link  |  Quote  |  Print  |  Notify Moderator
I use two of them. One in front of the tires and the other behind. That stopped alot of the bouncing and movement in the trailer.
2008 Jay Flight 30 BHDS 07 Silverado 2500HD & 02 Trailblazer
Me 46 the Boss 43
DD 15 & DD 12
Brichon-Frize
Blue & Gold Macaw
ScottandCathy
Liberty Twp, Ohio
Posted: 04/24/08 05:24am Link  |  Quote  |  Print  |  Notify Moderator
I also use 2. I put one directly under the entry door which is in front of the tires on the passenger side, and the second one on the opposite side behind the tires. I would say it eliminated about 80% of the movement. I am not sure you will eliminate 100% unless you put the TT up on blocks.
06 Dodge Ram 2500HD MegaCab 4x4, Cummins I6 5.9 CIT, 3.73 gears
Prodigy brake controller, Reese dual cam sway/WD
08 Jayco Eagle 314BHDS
Nights camped in 2008:24
Nights reserved for 2008:24
mooreadventures
North Carolina
Posted: 04/24/08 07:41am Link  |  Quote  |  Print  |  Notify Moderator
First I've seen of these... the concept certianly makes scence.
Mark & Tammy
'01 Excursion Limited, 4x4, V10, RoadMaster Active Suspension
'01 Prowler 31G
Equal-i-zer Hitch - Prodigy Brake Controller
wasper600
Nebraska Panhandle
Posted: 04/24/08 09:14am Link  |  Quote  |  Print  |  Notify Moderator
I use one across the back under the bumper. Huge improvement. We didn't have a problem with the 'bounce' up and down, but we had some 'side-to-side' what was rather bothersome. This stabilizer works well, is very lightweight, and easy to use.
W&M
2008 Keystone Cougar 268RLS
2008 F250 Super Duty XLT ExtCab
Hornet28BHDS
Parker, PA
Posted: 04/24/08 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
They look like a great alternative to those JT's Strong Arm Stabilizers. I think they ran around $300 for a set.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
V10 man
Mesa, AZ
Posted: 04/24/08 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
2007 Dodge 6.7 Cummins, 6sp auto, Quad cab, long bed, white, Prodigy
2009 Shockwave T29FBSP, white & blue, tan interior, 4000W Onan, Reese Dual Cam 15K/1,500.
Mike Schriber
San Diego, CA
Posted: 04/25/08 12:14am Link  |  Quote  |  Print  |  Notify Moderator
One thing to keep in mind with the Wayne's Stabilizers is that they need a flat surface on the trailer to act upon. If you have gas lines below the frame or a spare tire mount on your bumper they won't work without shims.
BAL now makes their own version of the J.T. Strongarm stabilizers for a lot less money.
Mike
2005 Chevrolet Suburban K2500 LT (8.1 liter with 4.10 gears)
2004 Starcraft Homestead 29BHS (16,000 pounds combined)
Twin Honda EU2000i Generators - 12' Porta-Bote
Prodigy / Putnam XDR / Equal-i-zer
SoCal Family Campers
