bbarbee
Glendale, AZ
On my 08 Seneca 34SS, when I dump the tanks, the black tank goes fairly fast (normal from past experience), but the gray tank dumps extremely slow. Even after 5 or 10 mins, it can still be one third full. If I wait long enough, it will go to empty on the gauge.
Does anyone else have this problem or have an idea where to start looking?
Bob and Becky Barbee
2008 Seneca 34SS
2000 Saturn L-Series Toad
rogerswann
Rhode Island
I have heard of the cutout for the drainpipe has been found in tanks before.
ASA Glamis
Rancho Cucamonga, CA
I have noticed this on my 2007 35GS Seneca. It seems that the gray tank is buried somewhere between the tires and I think that the drain line has a few turns in to get to the dump valve. It will drain just not as fast as the black tank that has a more direct line to the dump valve.
2007 Jayco Seneca 35GS
Scott9413
New Orleans
06' 35GS - Same problem.
Scott
2006 Jayco Seneca HD 35GS
2004 F250 Crew Cab (for sale)
az99
N.Y.
Same problem. Mine has to have the front of the MH level or higher. If not, the gray tank will only drain down to about 1/4 tank.
funmover
Las Vegas
I have a 2008 34SS with the same problem. I was wondering if there was something blocking the gray tank, syrofoam, wood shavings or what?!?!?
az99
N.Y.
funmover wrote: I have a 2008 34SS with the same problem. I was wondering if there was something blocking the gray tank, syrofoam, wood shavings or what?!?!? I suspect either that or the piece of the tank left after drilling the hole. It is either a 1 1/4" or 1 1/2" drain pipe coming from the tank. It should drain faster than it does. I tried back flushing but it did not help.
BEVAR
Lake Worth, FL
Same problem here. It does drain...it just takes 5 minutes or so.
Beave
'06 35GS
trnfla
Tampa
My winnie has the same issue. I had the dealer look at it and it seems to have gotten better. I don't know what they found or did.
Have a great time camping,
Terry
Please visit my Photos and Blog NiceCamps.com
New (2 me) 2004 Winnie 31C
2006 Expedition EB, replaced by scooter and 2008 Mazda 3
Had 2007 Zeppelin EZ190, Prodigy, Equalizer
crawford
Dandridge Tenn.
you have a vent for gray water and black water so you should have to pipes go to roof pull off the covers I found that mud dubbers built a nest in pipe, clean it out and works great now
