RV.Net Open Roads Forum: Class C Motorhomes: Emptying Seneca tanks
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Emptying Seneca tanks
bbarbee
Glendale, AZ
Posted: 04/24/08 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
On my 08 Seneca 34SS, when I dump the tanks, the black tank goes fairly fast (normal from past experience), but the gray tank dumps extremely slow. Even after 5 or 10 mins, it can still be one third full. If I wait long enough, it will go to empty on the gauge.
Does anyone else have this problem or have an idea where to start looking?
Bob and Becky Barbee
2008 Seneca 34SS
2005 Jeep Liberty
rogerswann
Rhode Island
Posted: 04/24/08 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard of the cutout for the drainpipe has been found in tanks before.
ASA Glamis
Rancho Cucamonga, CA
Posted: 04/24/08 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have noticed this on my 2007 35GS Seneca. It seems that the gray tank is buried somewhere between the tires and I think that the drain line has a few turns in to get to the dump valve. It will drain just not as fast as the black tank that has a more direct line to the dump valve.
2007 Jayco Seneca 35GS
Scott9413
New Orleans
Posted: 04/26/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
06' 35GS - Same problem.
Scott
2006 Jayco Seneca HD 35GS
2004 F250 Crew Cab (for sale)
az99
N.Y.
Posted: 04/27/08 05:34am Link  |  Quote  |  Print  |  Notify Moderator
Same problem. Mine has to have the front of the MH level or higher. If not, the gray tank will only drain down to about 1/4 tank.
funmover
Las Vegas
Posted: 04/30/08 12:01am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 34SS with the same problem. I was wondering if there was something blocking the gray tank, syrofoam, wood shavings or what?!?!?
az99
N.Y.
Posted: 04/30/08 05:16am Link  |  Quote  |  Print  |  Notify Moderator
I suspect either that or the piece of the tank left after drilling the hole. It is either a 1 1/4" or 1 1/2" drain pipe coming from the tank. It should drain faster than it does. I tried back flushing but it did not help.
BEVAR
Lake Worth, FL
Posted: 04/30/08 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Same problem here. It does drain...it just takes 5 minutes or so.
Beave
'06 35GS
trnfla
Tampa
Posted: 04/30/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
My winnie has the same issue. I had the dealer look at it and it seems to have gotten better. I don't know what they found or did.
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
crawford
Dandridge Tenn.
Posted: 05/07/08 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
you have a vent for gray water and black water so you should have to pipes go to roof pull off the covers I found that mud dubbers built a nest in pipe, clean it out and works great now
