RV.Net Open Roads Forum: Fifth-Wheels: 5 th airborne install
 > 5 th airborne install
Duck
Miami Lakes, Fl
Posted: 04/29/08 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
ford truck guy wrote:
I have another question , what if you don't add brass air valves? Are you still able to add air to the valve as is?? What about the capture plate, I purchased the plate made to bolt on to the 5th airborne, my dealer is telling me that the plate still needs to be welded on?? My thoughts were that if I needed to get towed in an emergency, I could just un-bolt the capture plate allowing any hitch to pull the trailer
Joe
Joe, I have the new Pullrite capture plate on my new Fifth Airborne. If your Fifth Airborne is model 5AB-S500 then you can use the new capture plate that mounts with only four set screws. The reason for adding the brass fittings was that the capture plate made it almost impossible to add air to the bag. No need to weld if you have the above model.
Don
Don
08-FORD F350 PSD
08-Hitchhiker II 34.5 UKSBG
ford truck guy
Pennsylvania
Posted: 04/29/08 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Joe
Don
Don
Don, I do have that model and thanks for the input.I have called my dealer and advised them not to weld anything..
Joe and Lori
2005 Ford F250 SD 6.0
08 Montego Bay
Joezilla
Mesquite, TX
Posted: 04/29/08 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Boaterman,
You are my hero!!
Joezilla
2007 Ford F350 dually PSD 2WD King Ranch
2007 KZ Montego Bay 36 REB-3 38ft 11in. 5th Wheeler
Kountryguy
Emery,SD
Posted: 04/30/08 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Thinking about getting one of these. What is a capture plate? Have not seen this mentioned anywhere. Thanks.
Duck
Miami Lakes, Fl
Posted: 04/30/08 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Kountry, I would recommend that you go to their web site. You can learn a lot about the hitch and how it works. The capture plate fits on your king pin box and is necessary to make the hitch work properly.
Don
Kountryguy
Emery,SD
Posted: 04/30/08 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Went to their website and saw no mention of a capture plate. Maybe I am looking in the wrong place.
SteveB
Rhode Island
Posted: 05/01/08 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Isn't the capture plate for a Pullrite slider?
Answering my own post...Yes it is.
Kountry, if you have a Reese or other manual slider (or non slider) you don't need a capture plate.
'01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
boaterman
Arlington, TX
Posted: 05/05/08 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Joezilla wrote:
Boaterman,
You are my hero!!
Joezilla
Joe -- Your check is in the mail.......
I finally hitched the 5er to the truck and tried to fill the air bag to the line. I put the max air pressure 120psi into the bag and could not see the line. I moved the bag into every hole and got the same results. Finally I tried the rear hole, and if I put the air in while un- hitched, and then hitched up, the shock would stay positioned on the line. I have a 3000# pin weight.
Does this appear normal????
2007 Ram Laramie 3500 Quad drw 4x4, 3.73, 6.7, 6 speed auto.
2005 Open Road 349 RLDS-5,  B & W Companion, Blue Ox Bedsaver
Fifth Airborne Air Pinbox, Timbrens
+The Super Wife and co-driver
Open Road Owners Club -- Texas Chapter
SteveB
Rhode Island
Posted: 05/05/08 10:39am Link  |  Quote  |  Print  |  Notify Moderator
My 5th AB came in last Friday, took it home Saturday. That sucker is HEAVY! 135 lbs written on the box. Will try to get it installed this week some time.
SteveB
