RV.Net Open Roads Forum: Fifth-Wheels: Planning a modication to our slide outs
 > Planning a modication to our slide outs
West Coast FT
California
Posted: 04/26/08 01:01am Link  |  Quote  |  Print  |  Notify Moderator
We've full timing in our Cedar Creek and while we have double pane windows we're finding that a couple of the slideouts let cold drafts blow right in.
One idea was to cut pipe insulation to fit against the RV wall fitted between the wall and slideout. My suspicion is that the wall is not perfectly plumb and as a result an air gap exists between the s;ide out and the wall.
Anyone tried this idea before?
TV 02' Chevy Silverado 3500 8.1 liter 4X4, Rancho 9000, Airlift Airbags 2 Honda EU3000,plus paralleling kit (6000 Watts peak!)
Old Rig (03' Lance 1161) Boy I missed it!
New Rig (05' Cedar Creek 37RDQS)
Second new Rig 1996 Damon Intruder 325B
Bumpyroad
Virginia
Posted: 04/26/08 04:45am Link  |  Quote  |  Print  |  Notify Moderator
I haven't done nor needed it but don't know what some of that self sticky foam insulation like they sell for windows, etc. wouldn't help seal it.
bumpy
KMC6970
Houston, TX
Posted: 04/26/08 05:24am Link  |  Quote  |  Print  |  Notify Moderator
I cut the pipe insulation in half and put it in where there is a gap. It is usually along the top of the big slide as they sag over time. Big thing is to try and remember to remove the insulation before you pull the slides in all the way. I don't pull off the tape. Works for me.
Voyager Mike
Hamilton, MT
Posted: 04/26/08 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Did you crawl under your slides and check them for adjustment? Some have adjusting nuts which can "travel" over time. Perhaps yours is no longer going out all the way. But be careful. You also do not want to bulge the sides of your trailer. This may be a good place for a trained technician.
Mike
rvsatek
AZ, USA
Posted: 04/26/08 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Properly adjusted slideouts should provide a good seal. If you don't know how to do it then I would take it to a good shop or find a good certified mobile tech.
Larry
1994 Ford F250/7.5L/410 gears
2001 Keystone Sprinter 276RLS 14' slide
rick_niagara
Niagara Falls, Ontario, Canada
Posted: 04/26/08 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with some of the posted members, adjusted by RV technician sounds like a good plan!
2008 Fleetwood Prowler 235RLS
2005 Dodge Ram 2500 4x2 5.9L Diesel 3.73Limited slip 6speed manual
Pullin' 5ers since 1988....Have a nice day
Snow Dog
Regina, SK Canada
Posted: 04/26/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Check and make sure the foam around the slides are not rolling under. This can leave a gap and let air in. The bottom of our bedroom slide did this and just pulling it back into shape fixed the problem.
1998 Dodge 3500 dually turbo.
1999 Nu Wa Snowbird Legend 31 + 2 RLTGBW
1998 12' Porta-Bote with 5HP Nissan and Electric motors
2 X Honda 2000EU
Years and years of experience to gain!!!
Cat320
Western AR
Posted: 04/26/08 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Agree.
If correctly adjusted, they should seal when extended and when closed.
