Ovaleye
Iowa
The RPMs on the tach jump, my ABS and ATC lights flash and the water and tranny temp read low. Except for the gauges this happens intermittently
Allison and Cummins wont work on the chassis electrical and the dealer
had a guy look at that was dumber than I am. Anyone had this problem?
Tim
2003 Safari Sahara
2006 Jeep Liberty
Jack_Diane_Freedom
Lindsay Ont, and Gulf Coast Florida
Had a similar problem on my Silverado P/U with gauges flipping and speedo jumping around.After a week in the shop they found a small ground wire on the engine side of the firewall almost in front of the steering wheel only up higher that was loose. Tightened this and all was ok.
CREATO
Beautiful Harvey N.D.
have a 1996 freightliner fld semi done the same thing about 2 years after i bought it and it also was a bad ground wire. I have also seen this on farm equipment and it was a snap together connector that was not fully pushed together hope this helps you
I DON'T RENT OUT SPACE IN MY BRAIN
dougrainer
Carrolton
Is your chassis a Monaco built Roadmaster Chassis? Doug
JUrban
Delaware
Depends on your chassis and how the wiring is set up. I had a 2004 Freightliner under a 2005 Diesel bounder that looked like a pinball machine coming out of Dawson City, Yukon a few years ago. Ran fine but not even the speedometer read correctly. It turned out to be 2 bad pins in the MMDC system. Two hours with a super Freightliner dealer in Red Deer, Alberta and I was on the road.
Finding the right guy is more important than finding the bad part. I suggest a call to your chassis manufacturer as a first stop.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
Ovaleye
Iowa
Its a Road Master chassis
