wolfe10
2cyber71 wrote: The Cummins manual says " fuel and coolant filter change at 15,000 miles...
Careful here. The Coolant "filter" comes in different amounts of SCA (Supplemental Coolant Additive). You need to test the coolant to determine the correct amount (units) of SCA that need to be added. You may need none, 4 units, 8 units, etc. Correct concentration means testing and adding what is needed, not just changing the filter.
These test strips are available from Wix, NAPA, Cummins, etc.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
John S.
Northern Virginia
2cyber71 wrote: I'm getting that wrench....and an extra filter after what I've seen about bad fuel posted in the past.
I have a primary and a secondary and carry two changes. A full load of bad fuel will take three filters to clean out. Well I have 200 gallons so it may differ for you. BUt I had to change mine every 100 miles last time.
John
2001 42' Foretravel U320
2007 Bornfree 24 Painted
2001 Jeep Wrangler
2007 Burgman 650 Executive
Susie and Dolly (Cavalier King Charles Spaniels)
Dolly now in our hearts and thoughts 8-27-05
Doodle a Black and Tan Cavalier
Lolly a Ruby Cavalier
lanerd
Ridgecrest, CA
Our rig has about 8,500 miles on it and the manual recommends a 11,000 oil/filter change (CAT C7). Since we are heading for a 9000 mile trip to Alaska, I went ahead and did a complete oil/filter change for the engine and generator. I also installed two new fuel filters and will carry an extra set with me on the trip.
Ron
Ron & Sandie
'08 Safari Simba SBD35
86 Toy 4x4 P/U for Toad.
Tow Bar: Sterling
Brakes: Unified
Toys:
Yamaha 660R Raptor (mine)
Honda 350ES Rancher (hers)
64 Fairlane w/351c - 4sp
Both Fed CS Retirees
Hobbies:
DW's: Quilting
Mine: DW
RETIRED!! How sweet it is....
Economical Handyman
S. California
Ivylog wrote: Unless you get a bad batch of fuel they will last 30K+ miles. One batch of bad fuel will clog them if you put them on the day before. Fortunately bad fuel is not a problem but it does happen. On his ISL you just put the new filters on and turn the key on/off several times to prime. Might want to buy a filter wrench that fits if you do not have big hands. I test my water and add conditioner as needed.
I guess I am a little gun shy when it comes to fuel filters, since I have had 2 major problems with the CAPP system on my ISL.
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
Sully2
Cincinnati
Economical Handyman wrote: Ivylog wrote: Unless you get a bad batch of fuel they will last 30K+ miles. One batch of bad fuel will clog them if you put them on the day before. Fortunately bad fuel is not a problem but it does happen. On his ISL you just put the new filters on and turn the key on/off several times to prime. Might want to buy a filter wrench that fits if you do not have big hands. I test my water and add conditioner as needed.
I change both of my fuel filters at every OIL change..
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
jaxd
So CA USA
As a matter of course I change the fuel filters whenever I change the oil which is usually once a year. Penny wise pound foolish not to change them.
jaxd - F140757
2004 Excursion 39' triple slide 350 Cummins Turbo
Toad 08 Honda CR-V EXL
great dane
borrego springs ca.usa
I just had my 400 isl/ Freightliner chassis serviced using Cummins/Freightliner service recommendations as a guideline. I do it once a year, as I never exceed 15000 miles in a year. This way I am not compromising my six year warrenty on engine/trany & chassis.
GD
Sully2
Cincinnati
Here is a little tidbit I picked up from the latest issue of Country Coach's magazine.( summerized of course)
"15,000 oil changes were designed for heavy duty engines that run all the time under load...they are NOT ( repeat NOT) for the typical MOTORHOME user and oil changes of 6 months or 6,000 miles ( remember..avg owner runs about 6000 miles a year!!) are more inline with "proper maintainence" and having a chassis lube at the same time."
It goes on to state "when did you ever heard of a diesel motorhome owner complaining that he had a problem caused by OVER maintainence"..??
Norm Payne
Livingston, TX
This can not be correct because your engine does not have a coolant filter. Cummins dropped the coolant filter in 2005 ISL engines.
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
spitfirepete
Great Outdoors RV resort
Norm Payne wrote: 2cyber71 wrote: The Cummins manual says " fuel and coolant filter change at 15,000 miles...
Coolant filter is installed at the option of the coach manufacturer....I believe some Cummins engines after 2005 do have them depending on the make of the coach....although Cummins reps told me that Cummins is comfortable without them due to improved coolants.
Peter and Linda
2007 Mandalay Presidio ISC
1975 Triumph Spitfire toad
2007 Saturn Vue toad
Bichon and Cocker (spoiled puppies)
