jesterdog
Wife said she was driving the Excursion (V-10) and came to a stoplight and realized that it had died apparently as she was slowing to a stop. After she realized that she had to put it in park, it started right back up.
She said that the CEL was on before she cranked it up. The CEL did not stay on after it started back up.
She drove into town, picked up a BD cake, came home. No more troubles. Is this a well known issue with V-10s?
I've heard of the 7.3psd and bad CPS. But, this is a V-10.
Any ideas?
2001 Excursion 3.73 geared V-10
2006 Coachmen Spirit of America 24TBQ
the_vfox
Minneapolis MN
I would take it down and get the code pulled. Better safe than sorry.
Fox and Angel (Vinnie and Brenda) fuzz ball cats
Don't call me on the weekend, Im out camping.
2004 Chevy Silverado LS 2500HD 4x4 DA 4dr
2003 Jayco Eagle 263 29'Super Slide
Dell Inspiron 1520/WIFI
Go Blue, US Air Force(retired)25 years
Adam H
People's Republic of California
It happened to my 5.4 Expedition once a couple of years ago. I worried for a while but since it never happened again I blew it off. Probably will not have any codes stored for such an intermittent concern.
Adam
camping man
Central Fla.
Most likely an idle air valve sticking a bit, but when you pull codes you could have half a dozen in their from it stalling, you have weed out the bogus codes.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
tom_kat
way upstate new york/lake george area
had that happen a few times on the dodge but no codes show up at all had the air intake cleaned out, thru in some injector cleaner and that helped some but hasnt done it lately since the weather warmed up.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
Vulcanmars
Naples, FL
Yep. Idle control motor.
Often does not set a code but stalling gets worse. Eventually it will only start/idle with a little bit of throttle.
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
Pullrite SG 16K
1st TH 02 Keystone Tailgator
rob85546
Hot arizona
You ever change the fuel filter on the frame??? My expediton did that a couple times, changed the filte and plugs, filter was nasty and plugs pretty well worn..
also she said the CEL was on before.. well maybe when it died she seen it on, becasue it lights up when the key is on and engine not running??
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
Shendoh
Baltimore
You might want to check here....http://www-odi.nhtsa.dot.gov/
You wil need to drill down............
About half way down I found:
Make : FORD Model : EXCURSION Year : 2001
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Number : 14454 Date of Bulletin : NOV 01, 2000
NHTSA Item Number : 616538
Component : ENGINE AND ENGINE COOLING ENGINE:GASOLINE
Summary :
SOME VEHICLES EQUIPPED WITH 7.3L ENGINE MAY EXHIBIT A NO-START OR ENGINE STALL CONDITION. ENGINEERING IS INVESTIGATING. *TT
Check to Request Research. Submit below.
Some of the latest reports indicate a gelling of the fuel.
Shendoh
Shendoh
rob85546
Hot arizona
He has the V-10 gasser, what you found is for the Powerstroke diesel.
Shendoh wrote: You might want to check here.... http://www-odi.nhtsa.dot.gov/
Summary :
Shendoh
rlh6805
Michigan
Vulcanmars wrote: Yep. Idle control motor.
Right on the money!!!. It's the IAC. It is behind the throttle body on the V10's. Two bolts and an electrical connector to remove. Use some carb cleaner and try to clean it, if there are still problems you will need to replace it.
Rob and Cindy in Michigan
2004 Prowler Regal
2001 Ford Excursion V10 4x4
Tasha, Deanna (RIP), and Abby (our dogs)
