RV.Net Open Roads Forum: 2nd A/C in a toy hauler which end do I put it on.
Search only in Toy Haulers
 > 2nd A/C in a toy hauler which end do I put it on.
Fleahop
Alabama
Posted: 04/27/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like I'm buying a 3712ts Raptor. Experiance tells me I want the second a/c. My question is do I want to install it in the rear or in the bed room? I've never owned a toy hauler. Note I will be using the rear for a kids bed room more than just storage. I need to hear from some of you that have learned the hard way. Thanks!!!
paul turner
Bakersfield
Posted: 04/27/08 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Put it in the main bedroom upfront, it replaces the existing vent. Pre-wired there too. For the garage, place a fan in the doorway pushing cool air into the garage, this works for us, but we only have the single 15k unit. You may not need to do this with two units running.
paul
HarleyMedic
Sour Lake, Texas
Posted: 04/27/08 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Bedroom.
Big Sexy and BonBon
2003 Dodge 2500 4x4 Laramie Cummins Auto, Edge EZ, AEM Brute Force, Timbrens, B&W.
2004 35SRV Victory Lane
1998 Harley Road King (Mine)
2003 Harley Road KIng (Hers)
2004 Yamaha Grizzly LE
JRBurn
Lake View Terrace, Ca. U.S.A.
Posted: 04/27/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Bedroom
06 Dodge CTD Quad Auto DRW 4X4, 4.10 & Exhaust break.
08 Weekend Warrior SLC 3905 Dual Slide
05 Polaris Ranger 4x4
05 Yamaha YFZ450, 04 Susuki Z400
06 Honda 250EX
CORVA, ASA, Action
2btowed
glendale,az
Posted: 04/27/08 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Bedroom,close vents in front bedroom from rear unit,then Fantastic-fan on floor by garage door.Works for me in Az. Also look at putting up foil insulation on windows in garage.Everthing helps...
Fleahop
Alabama
Posted: 04/28/08 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Keep your fingers crossed I am going to PC Beach tommorrow to close the deal on a new raptor. I never bought a new RV always used and I have mixed emotions about taking the hit on buying new. What are some of your opinions on this subject?
PS looks like the air is going in the bedroom.
DavidM49
Bartonville, IL
Posted: 04/28/08 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Fleahop, ensure you go through every cabinet especially under the sinks to ensure everything is the way it should be. I discovered only after winterizing mine this year that the propane detector was not hooked up. Have them pressurize the water system to ensure no leaks are evident. Our dealership threw in an in-line water filter in the kitchen only to botch the installation and have it leak. I finally just took it out. Check for loose or missing screws and if any are there, make them fix it. While overall happy with my Raptor, being a newbie when I bought it, there will be more I check if I ever buy a new RV again. In terms of the 2nd AC, we did not opt for it and I have been happy with out it even on some incredibly hot midwest weekends down in Missouri. I don't have anyone sleeping in the garage but the rest of the camper was very chilly with just one. The AC is ducted to the garage on my Raptor and I would think a fan between front and back would be good. Good luck!!
Big Dave
2008 F350 Superduty 6.4 TD "Bumbles"
2007 Keystone Raptor 3814
2004 Polaris Sportsman 700 EFI
2008 Yamaha Raptor 250 SE
2007 Yamaha YZ85
2006 Polaris TB250
Assorted other toys
2 Boys who only know one speed
dchurch
South Carolina
Posted: 04/28/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Fleashop -
I strongly recommend you to consider 2nd A/C in garage - especially in the south. Actaully, we have a total of 3 a/c - and use all 3 during the summer. The gargage seem to get much hotter than bedroom. Without a doubt, if I had only two a/cs it would go in garage. I have a Fuzion 3612
dc
McKenziek
Visalia, Ca
Posted: 04/28/08 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
Ask yourself this question; Where will I spend more time trying to keep cool, the garage or the bedroom?, then put it there. btw, Weekend Warriors come pre-wired for a 2nd a/c in the bedroom, probably others too, that should give you a clue.
'08 WW CR3705, '07 F350, '07 YFZ450, '06 Rhino, '05 DS650
My Photo Albums
longtrailer48
Kent, WA
Posted: 04/28/08 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have two 15K's. One in the kitchen living area, second in the front bedroom. I would put it in the garage next time. It would be cooling the bulk of the living areas that way (we really use the garage a lot for gaming, etc. with a lot of people). The ducting in the ceiling goes to the front bedroom as well as the garage. However, the small amount of air coming out of those vents compared to the actual main vent at the unit is not sufficient to adequately cool the garage, but would do the front bedroom. So the main unit, ducted forward to the bedroom, and the back unit on it's own I think would work the very best. I love the Raptor by the way...good choice! I'm not sure how their ducting and wiring can be run. You'll have to check on that. I had a Fantastic Vent wired into the garage ceiling and that pulls the hot air out and the cool air in so it's working just fine, just not the way I would do it again. I did maintain 71 degrees in 105 degree heat last summer though in Idaho. Not bad? Just some more info for you. Hope it helps.
-Jeff
2000 F350 4X4 7.3PSD CC SB SRW Superglide 18K 4" Flowmaster K&N Garrett Turbo Pwr Chp 8-21 MPG
2008 WW FTL4005+5 5th Wheel Toyhauler 48'x102"x13'-6" 3 slides
