RV.Net Open Roads Forum: Travel Trailers: Propane consumption.
 > Propane consumption.
Neilm_108
Calgary, AB
Posted: 04/28/08 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Dixonmatco wrote:
The only two possibilities are:
1. nasty leak
2. Not filled properly
There is no other way to consume that much LP doing what you were doing.
Agreed.
kearlms
Rexburg, ID
Posted: 04/28/08 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Neilm_108 wrote:
1. nasty leak
Agreed.
I would have to agree that one of these is a possibility. We just got back from 3 days out and it got down to 20 - 25 each night and we did not go through one of the propane tanks and DW had it set at 70 all night. I would check into it a leak or filling properly and trying again. Hope you figure it out. Good luck.
smkettner
Posted: 04/28/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Fill the tanks completely and try again.
NHguy
NH
Posted: 04/28/08 10:09am Link  |  Quote  |  Print  |  Notify Moderator
I'd go with smkettner, unless there is an obvious air leak allowing heat to escape. You can't be sure of a really filled propane cylinder from the original fill up.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
ferretgrandpa
Missouri
Posted: 04/28/08 10:12am Link  |  Quote  |  Print  |  Notify Moderator
It has to be a leak or improperly filled tanks.
Just went all winter (KCMO) and never used more than 9 lb a day(temps to -2F). Have single pane windows and kept a comfortable 72 at ALL times.
Winter avg was 6 lb/day (10/07 to 4/08).
94 F250 Flatbed
RBW Lil Rocker 15K
08 Flagstaff 8526 RLS
02 Sierra RKSS
1 Ferret
coptalker
Western Colorado
Posted: 04/28/08 10:39am Link  |  Quote  |  Print  |  Notify Moderator
I've camped for 7 days in October with temps down to around 10-15F and didn't use both 30# bottles. I realize those are larger than yours, but the temps were quite a bit colder. I don't supplement with a ceramic or any other source, just the furnace and I don't go cold. I do turn it down to around 55-60 during the day, but evenings I warm it up to around 70. I think there is either a propane leak or a significant air leak that's bringing in too much cold air.
Please check the system for leaks. I'd hate to hear about a gas leak causing you any problems.
Good Luck!
Glen
2004 Dutchmen 27BG, Rocky Mountain Elk Edition
2002 Chevy Silverado 2500HD 8.1/Ally
2 boys, 12 & 14
a friendly black lab
a couple of decks of cards
a cold beer
Life is too short to sweat the small stuff.
scmopar
co
Posted: 04/28/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
SemperFiCop wrote:
scmopar,
Congratulations on your new Roo 26RS.
Did you get it at RVW?
How much weight does the bunks hold?
I can't find anywhere they specifically say the weight. the majority of documentation have seen say the bunks hold 200 to 250 lbs.
Bob
longwayfromhome
Alaska
Posted: 04/28/08 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
scmopar wrote:
SemperFiCop wrote:
scmopar,
Bob
Bunkends on the Rockwood Roo hold something like 1200 lbs each. If you're talking about something else, please disregard. Even regular bunks in TT's hold 250 to 350 typically.
SemperFiCop
Posted: 04/28/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
longwayfromhome wrote:
scmopar wrote:
SemperFiCop wrote:
scmopar,
Bob
Yes,
Thank you
Was curious how much weight the quad bunks (each one) were rated to
hold on the Roo model
Chuz
Sylvania, Ohio
Posted: 04/28/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a leak to me. Definetly invest in a couple of ceramic heaters. We have 2 and our furnace barely ran. After all you are already paying for electric at most campgrounds. I used about 45-50 pounds on a week long trip but only because I accidently had both gas and electric switched on for the water heater.
Chuz
2003 Ford Expedition XLT 2WD 5.4L Triton V8
2007 Surveyor by Forest River SV304 34'TT
