RV.Net Open Roads Forum: Tech Issues: Ford 460 cuts off over 35mph.
 > Ford 460 cuts off over 35mph.
lovemedic
nc
Posted: 04/28/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I got a 1988 36' Travel Master with a gasoline Ford 460. It will start up and idle just fine. You can rev it up okay...no problem. When you get on the road.. and get up to 35mph..or so...it dies. The only way to get it going again is to put it in neutral...and restart it. It will start right back up and again...idle fine. It did the same thing last year and I replaced the inline fuel filter..that looks like a upside down can next to where you put the gas in and waaa laa...it worked fine after that. Tried it again this year...but this time, it didn't solve the problem. Anyone ever had one do this before?
tncruiser
collierville,tn
Posted: 04/28/08 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Your catalytic converter may be plugged. Have had similar problems on two different vehicles and that was the fix. On one I just gutted it and put it back on and the car ran fine. It would not pass a emission test, but I wasn't required to do that.
Keith & Patty / TN.
2004 27rl Crossroads Cruiser
2006 Ford F-250 Lariat
The older I get. The better I used to be!
Big Katuna
Deland, FL
Posted: 04/28/08 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Fuel injected or carb?
My Kharma ran over my Dogma.
Chris Bryant
DeLand, Florida, USA
Posted: 04/28/08 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
An '88 probably has a carb- the original has a fuel filter right at the carb inlet as well. Might check that.
(Note- I can never, ever remember how to spell car-bur-A-tor - and can usually not get close enough for the spell checker ).
-- Chris Bryant
My RV Service Blog
The RV.net Blog
mexfishguide
arkansas
Posted: 04/28/08 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
The 460v/8, had to have a lot of fuel pressure to operate right. The above is good advice, check at the carb. inlet and change that filter.
If you can not get the pressure up after changing filters - may have to replace the fuel pump, that year may have the pump in the fuel tank, can not remember?
Take care
Mexfishguide
lovemedic
nc
Posted: 04/28/08 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
cat converter was removed years ago. Can't be that. It's a carb.. I didnt see a filter near the carb...but i'll go check again.
YC 1
Yuba City Calif.
Posted: 04/28/08 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Check at the carb, not near. There may be a very fine mesh filter right on the carb. My dad used to pack two spares. Lack of power is most likely lack of fuel. I seem to remember a solid tube with a nut had to be disconnected right on the carb. I can't remember what it looked like but it was about the size of ten quarters stacked together if any memory cells are working.
lovemedic
nc
Posted: 04/28/08 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
okay...I found a filter that is where the line goes into the carb.. at least i think its a filter. It feels like a grinding stone...shaped like a cork..and is golden color. I guess thats the only thing that it could be. Ill go by the parts store tomorrow morn and get a new one and see if that fixes the problem. thanks everyone!
robatthelake
Vancouver Island
Posted: 04/28/08 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
If you are Lucky enough to have an Electric Fuel Pump and it likely has one It should be a "Holley Red" available at Checkers Etc for about $100 + ! Don't toss the Old one as it can be rebuilt for use as a spare!Don't be spooked by the "Not Legal for sale in California " label, We bought Ours in Yreka Ca.
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
NHguy
NH
Posted: 04/28/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Hey, while you are at it run some fuel through the system with the fuel feed disconnected from the carbueretor. You never know when you might get a chunk of something.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
