rich and char
N.J.
A question for Pullrite super 5th owners,
I two am a happy owner.
I have been looking for a locks to replace the pins that secure the hitch head to the base.
Any ideas or suggestions would be appreciated.
Thanks,
Rich
1-Beautiful wife
3-beautiful girls
Charlie-minpin
Sandy-Chihuahua
06 F-350 Lariat FX-4/4x4/CC/Lb/Psd dually / Bilsteins HD's/4" cat back/zoo-dad
07 Keystone Challenger 29TRL/Pullrite 20.5k Super 5th/Trail Air Eqaua-Flex
TnTtravelers
East Slope Sierra, California, USA
I too have been considering how to do this. I was thinking of using locking hitch receiver pins (smaller ones). I have seen both larger and smaller ones at Walmart. However, I don't know if even the smaller ones would be thin enough.
Of course, it would be best to find a set that has all of the pins keyed alike.
Please post up if you have any other ideas.
Tim and Tina (kudo too)
Livin' good, while the livin's good!
2005 Ford F350, 4x4, Crew Cab, Short box
2007 Everest 295TS 5th Wheel (Superglide hitch)
JT Stabilizers
smkettner
I would go to a locksmith and try to find a master lock that worked so that it could be keyed same as some other lock I have. I don't need one more key on the ring.
fordsooperdootydieselsmoker
OrangeCountyCalifornia
I got some stainless steel cotter pins at Home Depot, put them in the little holes at the end of the pins securing the hitch to the bed, and bent the ends of the cotter pins into an approximation of pretzels. It took some effort, I'll tell ya! And a bad guy would have a real problem getting them out, I have to use vice grips...so at least it will discourage all but a determined thief! It's the best I could come up with, and I have a Peragon Folding bed cover which protects the hitch too.
HERE You'd just need one or two....
rich and char
N.J.
hi fordsooperdootydieselsmoker,
I use those hitch pins for the base to the rails.
I e-mailed Pullrite about it . Lets see what They say / Suggest.
I'm just lookimg for a nice clean look that's effective security.
But may have to settle for less for now.
shadoow
South Texas
when i'm towing i use a padlock in the handle slot of the hitch head to prevent someone from disengaging the hitch pin. I also use this same setup when the trailer is parked. I remove the hitch head from the frame in the truck and re-engage it on the parked trailer then put a padlock in the handle slot. Now, the hitch head is out of my truck & locked to the trailer so less chance of someone stealing the hitch head or trailer...i hope
KZ 33P Toyhauler
2008 GMC 2500HD D/A
2006 Ultraclassic
1978 FLH
BREWCO
Heart of Georgia
Try LifeLong locks ( http://lifelonglocks.com/ ). I haven't tried or even looked at Lifelong site. You could E-mail them, they may be willing to help or come up with something.
2007 Toyota Tundra CrewMax 8262 - SR5 5.7L V8 Crew Max
2008 Coachman Chaparral Lite 267RLS
PullRite SuperGlide - 12,000
PullRite SuperGlide Trailer Plate Adapter Kit Part#: 3100
ronday
Heuvelton, NY USA
I drilled The hole larger in one pin in the head holddown, a pin in the main part and a pin in one of the four base pins. Then put a small padlock (in place of the clip pin) in each which are all keyed alike. Plus my hitch is covered with a tonneau cover when not in use or locked in my garage. Ron Day
2008 Chevy 2500HD D/A, Crewcab SB, Pullrite superglide
2000 Signature 34ft 5ver
2005 Sun-Lite 865 WS SB, truck camper
Ron - 29 yrs HS Tech Teacher (ret) 24 yrs USN/USNR Chief (ret)
Sheila - 29 yrs HS Home and Careers Teacher (ret)
DelawareCamper
Newark, Delaware
I know here at work we have master locks throughout our company, the shop guys said that you can order the locks as may as you need right from master all keyed the same, or differant keys per lock with a master to unlock all the locks ordered.
AntiqFreq
Sunny South Florida USA
When someone comes up with the locks that fit this hitch,
post it here, maybe some pics too - the hubby is wanting
to do the same thing to ours.
Thanks, JO
2007 Keystone Cougar, 291 RLS
2003 Ford F250, 7.3L, Lariat, CC, SB, 4x4
Isspro Gauges-overhead mount, 14K Pullrite Superglide
Firestone RideRite airbags & pressure gauge
Two Honda eu2000i generators, parallel kit
Bell Morningstar Canoe, bent shaft paddles
