Claybe
Denver, CO
I have 2 12 volt deep cycle batteries in parallel. They are matched and each are 115 amp hour batteries. I am looking for a cut off switch that I can turn off power to the camper and charge them separately and not have any power bleed over to the camper. Does anyone have a recommendation on what kind of battery cut off switch I should use? I bought one, but it says it is limited to 100 amps for 12 volts systems. Any help is appreciated!
Mandalay Parr
Phoenix, AZ
I would think 100 amps might be adequate. How many amps do you think you will be drawing?
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
ArcticDodge
Sammamish, WA
Most cut off switches are to take the batteries off line (out of the charging circuit) when the camper is plugged in for extended periods as most common converter/chargers tend to over charge the batteries over time. Let your on board unit charge the batteries and then use the disconnect.
2009 Komfort 256TS Yamaha EF2400iS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2001 Sebring Convertible
2005 DRZ400 - 2005 CRF150 - 2001 XR80
1 Wife 2 Boys
1 Trixie (Bichon Frise)
Only 27 years to retirement!!!!
delaware95
Akron, OH
I have been using a Harbor Freight battery cut off switch (about $5.00) with the same type battery arrangement for about a year. No problems. The switch is spliced into the main 12 volt supply line between the positive post in the battery box and the 12 volt distribution panel. Hope this helps...
sagexpman
Loveland, Colorado
I use the Perko battery switch. You can set it to battery 1, 2 or both and of course off. It's a bit large by works very well.
http://www.cabelas.com/cabelas/en/templa........=mode+matchall&Nty=1&Ntt=perko&noImage=0
edited 05/01/08 07:57pm by an administrator/moderator *
1998 HD Chevy Silverado 2500
- Super Charged Vortec 5.7
- Air Lift Suspension System
- Drawtite WD hitch with 1200# bars
- Drawtite DC sway control
- Honda EU3000IS
2005 Jayco JayFlight 31BHS
sum1
So-Cal
I'm also a Perko fan.
Wherever I happen to park
The 100 amp limite refers to the current passed NOT to the capacity of the battery
You have 230 amp hours of battery, You should not exceed 70 amps either charging or draw (Save for brief periods of draw) on those.
Your 100 amp switch will have no problems at all with that current.
Question: How much did you pay for those?
How much would a pair of US-220 Golf Cart batteries from Costco Cost?
(The US-220 would be 232 amp hours, basically.. The same)
2manytoyz
Central FL
Go to Walmart, buy a Perko battery switch as already mentioned. ~$25, rated at 350 Amps, IIRC. You'll find it in the boating section. Could go to a marine or RV supply store, and pay more for the same product.
I've been using these for years. Far better than a cheap blade type switch.
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
wla7
Warren, Ohio
delaware95 wrote: I have been using a Harbor Freight battery cut off switch (about $5.00) with the same type battery arrangement for about a year. No problems. The switch is spliced into the main 12 volt supply line between the positive post in the battery box and the 12 volt distribution panel. Hope this helps...
I used the same switch but installed it in the negative cable between the negative battery post and the grounding on the frame, (only because it was more convenient).
Wla
2007.5 Silverado 3500HD LTZ CC/DRW Duramax/Allison, 20.0k Pull Rite Super 5th
2008 Cedar Creek 36RLTS Center Point suspension & pin box
HubMonkey
Oklahoma
I have a Guest Switch on my Toy Hauler and it takes the batter out of the circuit so the converter will not charge the battery if plugged in.
Looks like this
Hub
Roosting The Dunes Not Your Mothers ATV Site
