RV.Net Open Roads Forum: Travel Trailers: THE 2008 TAB
 > THE 2008 TAB
TABIES
WASHINGTON
Posted: 05/01/08 12:02am Link  |  Quote  |  Print  |  Notify Moderator
WE BOUGHT OUR 2008 TAB LAST JULY, AND WENT ON OUR MAIDEN VOYAGE TO MORTON WASH. IT WAS GREAT AND ALOT OF FUN.ONE OUR FRIST OUTTING, WE TRIED THE HEATER AND IT WORKED FINE.... THEN IN FEB 2008 WE WENT ON ANOTHER JOURNEY, AND THE HEATER DID NOT WORK... AND NEITHER DID THE BURNERS ON THE STOVE... YES, WE HAVE ENOUGH PROPANE... ANY IDEAS??
AND A BIG HELOOOOOOOOOOOOO TO EVERYONE IN THIS GROUP....
HAPPY TRAVELING... DOUG & CHERIE
F1bNorm
Gardena, CA
Posted: 05/01/08 01:07am Link  |  Quote  |  Print  |  Notify Moderator
If this is on a fresh refill of the propane tank, I'm guessing you have air in the line from the recent disconnect. Turn on the stove burner and you should hear gas running. If it doesn't light, wait a few seconds with the gas on, then try again. If no light and no hiss, check to make sure the tank valve is on and the tank selector(if there is one) is in the correct position (on for that tank).
It can take a while for the air to clear the lines. Once this is done, you should be good to go until the next time you refill.
- Norm
F1BNorm
chevyman2
missouri
Posted: 05/01/08 02:33am Link  |  Quote  |  Print  |  Notify Moderator
Norm gave you some good advice. I would bet he is right. The only thing I might add is---I had a problem similar to that before. I ended up having a nest-or-web of some sort form in the gas line near the main valve. I undid the gas line at the stove and fridge, and again at the valve. I ran a strong air blast from the air compresser. After a good blowout the gas system worked great. I would bet that yours is not plugged up though.
Tim, Kathy and Ken (son) ASSOCIATES DEGREE OWNER
98 S-10,04 AVEO, 94 FIREBIRD
07 Coachmen 32FKS stays at campground
IF your going to be on a horse in a desert --- AT LEAST GIVE IT A NAME
TOTAL NIGHTS CAMPED IN 07 = = 62
SemperFiCop
Posted: 05/01/08 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forums,
Please do not use the cap lock when posting
It appears that you are yelling...
ScottG
Bothell Wa.
Posted: 05/01/08 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Your propane tanks may not have been totally filled by the dealer when it was new. This is common practice to save a few $.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
Hornet28BHDS
Parker, PA
Posted: 05/01/08 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Enjoy your new TAB!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
pmfinnegan2
S.E. Michigan
Posted: 05/01/08 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem many years ago. You mentioned you went out in Feb. Was it in frezing temperatures? In my situation a little moisture had gotten in the line and frozen to where no propane made it through. Have you tried it again since Feb?
pmfinnegan2
1998 Dodge Ram 1500 Sport
318 5.2L V-8, 3.92 Rear end
HD Transmission Cooler
2006 Max-Lite 24RS
Equalizer Hitch, Prodigy Brake Controller
Wife, 6 year old Daughter, and 2 year old son
dusden
Yosemite
Posted: 05/10/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
lets see some pictures of the TAB!
1969 Frolic
 > THE 2008 TAB
