TABIES
WASHINGTON
WE BOUGHT OUR 2008 TAB LAST JULY, AND WENT ON OUR MAIDEN VOYAGE TO MORTON WASH. IT WAS GREAT AND ALOT OF FUN.ONE OUR FRIST OUTTING, WE TRIED THE HEATER AND IT WORKED FINE.... THEN IN FEB 2008 WE WENT ON ANOTHER JOURNEY, AND THE HEATER DID NOT WORK... AND NEITHER DID THE BURNERS ON THE STOVE... YES, WE HAVE ENOUGH PROPANE... ANY IDEAS??
AND A BIG HELOOOOOOOOOOOOO TO EVERYONE IN THIS GROUP....
HAPPY TRAVELING... DOUG & CHERIE
F1bNorm
Gardena, CA
If this is on a fresh refill of the propane tank, I'm guessing you have air in the line from the recent disconnect. Turn on the stove burner and you should hear gas running. If it doesn't light, wait a few seconds with the gas on, then try again. If no light and no hiss, check to make sure the tank valve is on and the tank selector(if there is one) is in the correct position (on for that tank).
It can take a while for the air to clear the lines. Once this is done, you should be good to go until the next time you refill.
- Norm
F1BNorm
chevyman2
missouri
Norm gave you some good advice. I would bet he is right. The only thing I might add is---I had a problem similar to that before. I ended up having a nest-or-web of some sort form in the gas line near the main valve. I undid the gas line at the stove and fridge, and again at the valve. I ran a strong air blast from the air compresser. After a good blowout the gas system worked great. I would bet that yours is not plugged up though.
Tim-DW(Kathy)-DS(KEN)
04 AVEO-DD, 03 JEEP GRAND CHEROKEE, 95 Firebird(da toy)
07 COACHMEN SOA 32FKS(stress relief center)
If Im not at the CG---I'll be somewhere else!
Total nights camped in 08 = 45
SemperFiCop
Welcome to the forums,
Please do not use the cap lock when posting
It appears that you are yelling...
ScottG
Bothell Wa.
Your propane tanks may not have been totally filled by the dealer when it was new. This is common practice to save a few $.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
Hornet28BHDS
Parker, PA
Enjoy your new TAB!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
pmfinnegan2
S.E. Michigan
I had a similar problem many years ago. You mentioned you went out in Feb. Was it in frezing temperatures? In my situation a little moisture had gotten in the line and frozen to where no propane made it through. Have you tried it again since Feb?
pmfinnegan2
1998 Dodge Ram 1500 Sport
318 5.2L V-8, 3.92 Rear end
HD Transmission Cooler
2006 Max-Lite 24RS
Equalizer Hitch, Prodigy Brake Controller
Wife, 6 year old Daughter, and 2 year old son
dusden
Yosemite
lets see some pictures of the TAB!
1969 Frolic
TABIES
WASHINGTON
Thanks everyone for your info. We took our TAB to the dealer and the problem was that we needed a new pressure regulator and hosing. Thankful it was still on warranty. All is well. Since then, we've taken it out 4 times.. thanks again!
avatr
San Antone
chevyman2 wrote: Norm gave you some good advice. I would bet he is right. The only thing I might add is---I had a problem similar to that before. I ended up having a nest-or-web of some sort form in the gas line near the main valve. I undid the gas line at the stove and fridge, and again at the valve. I ran a strong air blast from the air compresser. After a good blowout the gas system worked great. I would bet that yours is not plugged up though.
you saying something got in the gas line and built a nest??? how?
