RV.Net Open Roads Forum: Tow Vehicles: what's your thoughts on 97 f 250
Search only in Tow Vehicles
 > what's your thoughts on 97 f 250
dennis 1
South Dakota
Posted: 05/01/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Just looking for opinion's, found a nice clean 1997 Ford f 250 4x4 crew cab, Has the 460 v8 auto trans. We have a 30ft trailcruiser now would like to go to a 5'er down the road. Is this a good truck for pulling? If you have this what do you pull and how do you like it? Any input would be appreciated. Thanks Dennis 1.
Trailer Trash 2
Santa Fe Springs, CA
Posted: 05/01/08 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Dennis that should pull that little trailer real easy, that 460 is a workhourse and gas is much cheaper than desil.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
1996 Ford F-350,Clydesdale, 7.3 Turbo W/Banks
Pulling a Super Fine Montana 2980RL
stetwood
Wisconsin
Posted: 05/01/08 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thats a pretty good size engine, but will imagine that it will require a fair amount of fuel . If the price was right, you could try it and when you decide on the 5ver, make the change then.
mexfishguide
arkansas
Posted: 05/02/08 05:29am Link  |  Quote  |  Print  |  Notify Moderator
That TV will handle most trailers, I had a 97, 460v/8. auto. - pulled a 35' with slide outs, and about anything else I wanted too. That engine taken care of will do the job - it is a real work horse. BUT I
have to tell you it truly enjoys gasoline!!!
Take Care
Mexfishguide
SemperFiCop
Posted: 05/02/08 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Does this sound about right?
1997 F250
V8 Cylinder, 5.8 liters
Horsepower: 210 hp
Torque: 325 ft-lbs
GVWR 8800 lbs
Maximum Payload 3890 lbs
Maximum Towing Capacity: 10000 lbs
Rubiranch
Salt Lake City, UT
Posted: 05/02/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
mexfishguide wrote:
BUT I have to tell you it truly enjoys gasoline!!!
Take Care
Mexfishguide
Of course it does, it's a Ford. I can hear mine sipping gas at night when it's just sitting there.
TV: Mint 1972 Ford F-250 XLT
TT: 1969 19' Excel; entertains 6, feeds 4, sleeps 2
You don't shoot to kill, you shoot to stay alive.
I don't carry because I have to, I carry because I get to.
I like new things-
- when they're 40 years old!
My pictures
MitchF150
Where I am now
Posted: 05/02/08 08:58am Link  |  Quote  |  Print  |  Notify Moderator
1997 F250
Horsepower: 210 hp
Torque: 325 ft-lbs
GVWR 8800 lbs
Yeah, for the '351ci' engine of that time...
I wouldn't want to tow a #10,000 trailer with it, but I'm sure you could move that kind of load around a farm and be just fine....
The 460 is around 7.5 liters or something like that..... It'll have a bunch more torque and a bit more hp, but it'll suck gas like a baby does a bottle!
If you can pay cash for it and it's not much over $5000 then you'll be okay... It'll get around 6 mpg with that load, so figure that into your equation as well..
Good luck,
Mitch
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/02/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
That's a good truck, and a good engine. Not an economical engine by any stretch of the imagination, but a strong one that will get the job done. If it has 4.10 gears, it will pull great. I wouldn't plan on using it for daily driving, the gas $$ will kill your budget. Get a small car or mini pickup for that. Used only for what it does best, the big Ford is a good choice. If it has low miles and has been taken care of and the price is right, you won't go wrong with that truck for most pulling/hauling needs. If you're thinking about a heavy fifth wheel trailer in the future though, I would pass up on the 3/4-ton and gas engine and get a dually with a diesel instead.
My truck in signature below has been a great truck and can do alot, but the price of gas and the single rear wheels do limit what it can do. It used to haul a camper and pull the flatbed trailer out to the desert for weekend fun. It pulls and hauls good with all the mods I've done to it (heavy duty springs, tires, wheels, shocks, sway bar bushings, 4.56 gears, etc). Now I can't afford that kinda fun anymore so the truck is used for work only, hauling a heavy welding utility body and when the flatbed is hooked up, it's hauling stuff for work instead of play. Gas is just too expensive now days.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Cricketts
Tacoma, WA
Posted: 05/02/08 11:05am Link  |  Quote  |  Print  |  Notify Moderator
I had a 1995 F250 towing a conventional. In asking other drivers what their experience was with the 460. The answer was very consistant; 8.5 mpg towing,10 City driving,12 on the higheway.
Cricketts
1999 F250 V10, auto, Short box S/C, 4.30 LS grs
2001 Prowler 27F 29ft 12ft push out
Reese HP Dual CAM, Prodigy
SemperFiCop
Posted: 05/07/08 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
So,
What did you decide?
