RV.Net Open Roads Forum: Travel Trailers: Replace Kitchen Faucet with?
 > Replace Kitchen Faucet with?
Kajtek1
CA
Posted: 05/02/08 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
canyonbound wrote:
Sorry to correct you. But all faucets today are water savers. And most have the water saving device in the aerator. .
Let me explain in different words. I know all faucets from about 20 years have flow restrictors that annoy lot of people.
Those devices restrict water flow, what is not exactly saving. Just like "water saving" toilets when often requiring flushing twice flush the saving down the drain.
What I was getting to is, that with single level faucet you open it in split second and adjust the temperature immediately, while 2 knobs faucets take several seconds of water running before you get it right.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
CarNut
Canton, MI
Posted: 07/28/08 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Is there a difference in drain pipe between RV and home? The ones in my trailer are black and seem thinner than the white stuff I have seen at stores. Can you use same glue?
2002 Chevy 2500HD Silverado 4X4 Duramax
Bilstein shocks
Prodigy Brake Controller
Reese Dual-Cam
2004 KZ Frontier 2809: 4 bunks in front, queen in back, good living in the middle.
SteveRankin
Sequim, WA
Posted: 07/28/08 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Residential faucets should work fine in a TT, although they'll add some weight.
I'd try to use compression fittings for the drain instead of using glue. Compression fittings come back apart later and make it easier to repair again. Gluing things together makes it more difficult to repair again.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 29V
2005 Chevy 2500HD Duramax 4X4 Crewcab
Hensley Hitch
TruControl Brake Controller
Our Beaver Technical page
Wildlife rescue at the Northwest Raptor Center
jmadre
Elizabeth City, NC
Posted: 07/28/08 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
This is exactly why I'm looking to change my faucets. I'm tired of filling the greywater tank while I try to avoid being scalded.
1994 Coachman Catalina 280RK behind a 2007 Chevrolet Silverado 2500HD 6.0L + Equalizer 10,000# + Prodigy brake controller
scpopupcamper
Lugoff, SC, USA
Posted: 07/28/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
lowes or home depot will work...find same type though
Martin Ray
CarNut
Canton, MI
Posted: 07/28/08 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
It looks like the RV drain pipes under my sink are ABS and the residential stuff is PVC schedule 40. I guess I need to find ABS parts and glue to make it work. This may be an issue for others also.
alcaudle
Asheville, NC USA
Posted: 07/29/08 06:31am Link  |  Quote  |  Print  |  Notify Moderator
If you can't find the abs, you can go from abs to pvc with a no-hub fitting. It is a rubber boot that has clamps on both ends. About $5 most places.
Alan, Donna & Savannah
alcaudle
Asheville, NC USA
Posted: 07/29/08 06:37am Link  |  Quote  |  Print  |  Notify Moderator
no hub coupling
