Twomed
On the road USA
The time to fix them is when they are new and the plastic is still "fresh". A 1 1/2" stainless washer will distribute the load from the screw, and help prevent cracking. You can buy a lot of washers for $92!!
Happy Trails
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
Phelpo
Ft Myers Fl
I'm going to repair mine this weekend....covers are made out of abs plastic.
I went to Lowes (only place I could find it) an bought some glue and a couple
abs plastic pipes. Drilled holes in the flat plastic and will glue to the underside of the cover.....will let you know how well it went.
Phelpo
oldusedbear
Brookings, OR, USA
I fed one to an 18 wheeler who was behind me. Got to looking at the second one and it was cracked too. These were also Dometic. And yes, about the price Kenneth reports.
Inspection of the second one showed that the plastic had become very weak and crumbly - - I don't think the condition of the plastic (on mine snyhow) warranted the effort for repair - - so bought two new ones.
Neither the old ones nor the new ones had any fiberglass in them. No reinforcement or anything. My opinion is they are pretty crummy material, and considerably overpriced.
The reason for spelling is so that all of the words don't look the same.
Old Blue
New York USA
Replace them, they owe you nothing.
Bill
Bill
36 Holiday Rambler
Harley Rider
Deen
Vancouver, WA
Luckily both of mine cracked while under the old three year warranty that Newmar had on the '02's. They replaced both of them at no cost, since I had them factory painted to match the full body paint when we ordered the rig they also repainted the new ones. Can't beat that! So far the replacments are about three years ols and show no signs of cracking.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
SS Slacker
Lino Lakes, MN
I just replaced my two Duo Therm A/C shrouds as the front one developed a crack. While removing I noticed the entire shroud was brittle from age and sun as compared to how flexible the new ones were. I got the original Dometic Duo Therm replacement shrouds from Camping World for $75 each. I thought it was worth it...
Dan & Tracy
2 kids ages 4 and 6
2003 HR Neptune 36PBD
300 ISB Cummins/5-Speed
MCDDY
Louisiana
Lost one several months back, didn't even know it till someone at the rally pointed it out. DuoTherm Penguin by the way. Got a replacement and when putting it on looked at the rear cover. Right front screw hole had crack running upward. Did the SuperGlue thing 1st then used some of that putty stuff you knead the 2colors together and when it gets hard it's hard. Worked it into the crack and redrilled the hole. Also got a 3/4" X1/8" aluminum strap and bent it around the front of the cover, drilled holes to match the screw holes. Also drilled holes in the sides of the covers, used sheet metal screws with washers. Might lose another tomorrow but it's sure stronger than it was.
Dave
GEAUX TIGERS
Dave, Miss Sue & Lucy the Terrorist Scotty Pup
Big Easy Area.
FMCA 153192
00 Windsor, 40' 2 Slide, ISC 350 HP.
02 Grand Cherokee Toad. Brake Buddy, Aventa 2
Phelpo
Ft Myers Fl
isn't this rving stuff fun????? This is why I love the forums, information from people who for the most part work on their own rigs.....people some times call me cheap, I think it is just prudent.
Phelpo
Phelpo
Ft Myers Fl
well I glued the ABS plastic to the covers, made them a lot stronger. Anybody
else do this??
How about painting the covers to protect them from the sun
Phelpo
