RV.Net Open Roads Forum: Toy Haulers: Another battery question
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Another battery question
chrisk500
Port Orchard, WA
Posted: 05/03/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
I am getting a new TH with 2 new 12 volt batts included. I took the 6 volt trojans out of my old TH before trading in and instead of just chucking the new batts want to tie them in with the 12 volts. Any problems with this setup? I will be installing an inverter on these as well. Can someone send or explain how the wiring would look like for this setup?? (2 12 volts and 2 6 volts).
Thanks!
Chris
2007 WW FS 2500
2006 Dodge 2500 CTD with 6" Lift, 35" tires
2005 Honda TRX 400 EX
2006 Suzuki 250
2004 Suzuki 160 LT
2006 Kawasaki 90
2005 Unison Desert Cat 90
JRBurn
Lake View Terrace, Ca. U.S.A.
Posted: 05/03/08 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not an electrical engineer but I do not think you should mix batteries, either all 12v or 6v
06 Dodge CTD Quad Auto DRW 4X4, 4.10 & Exhaust break.
08 Weekend Warrior SLC 3905 Dual Slide
05 Polaris Ranger 4x4
05 Yamaha YFZ450, 04 Susuki Z400
06 Honda 250EX
CORVA, ASA, Action
Chuck&Gail
In the Colorado Mountains
Posted: 05/03/08 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Two 6's in series are the same as one twelve. So + on 12, to + on 12, to + on one 6er. Negative on 12, to neg on 12, to neg on totally unconnected 6er. Now only connectors with no wires are a positive on one 6er, and a negative on other 6er, so connect them.
Finally connect TT wiring, positive to 12er positive, negative to 12er negative.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 4 Canada Provinces, & 2 Territories.
bldrbuck
colorado
Posted: 05/03/08 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
This may help!
The 12volt Side of Life
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
nny12972
NY
Posted: 05/04/08 06:46am Link  |  Quote  |  Print  |  Notify Moderator
You don't say what you have for 12V batteries, Chris.....but JR is correct.....in short, mixing different battery types/sizes/ratings/age-condition will shorten their life....even when using a smart charger......
UNLESS you isolate them into two separate banks and use a "1, 2, ALL" battery selector switch (bank one--the pair of 6V, and bank two--the pair of 12V), and charge each bank separately.....
If you're still in doubt, check with Trojan C-S....
J
