Cramalot
Arkansas
Was parked for a few weeks where the water had a lot of minerals in it (south Texas). Hot water tank was dripping slightly down the outside. Thought it was weeping out the valve, but found it was leaking around the plastic plug. The leaking caused light streaks down the side, very noticeable on the dark compartment door. Tried to remove streaks with soap and water, then with liquid polish. Not successfull. The streaking is not just visual, but you can feel that there is a deposit on the finish. After I got home I tried using toothpaste (for the grit), with no help, then lightly tried liquid CLR (brand name for calcium, lime and rust remover). Still no success. Was afraid to get to aggressive with the CLR since it says not to use on painted surfaces.
I need some suggestions, please !!
Glenn_Diesel
Southern California - Moreno Valley
Try vinegar on a soft cloth.
nbounder
Arizona mountains
Straight vinegar will generally remove calcium & lime deposits. If the surface is etched, you'll likely need to go to a body shop for a professional touch-up job.
Joe
forty4san
Hollywood, FL
I will also suggest white vinegar
Susan I
2008 McKenzie Starwood 32 FKD TT
03 3500 Quad HO Diesel DRW 4:10
Fulltiming, On the road somewhere.
RicJones
So. Cal.
Jet Dry for dishwashers works pretty good.
stevelv
FullTimers at Last!
I used a 'washless vehicle cleaner' called Fastwax - it cleaned the water spots off easily, left over from rinsing the RV after washing with our really hard Las Vegas water.
I know you can get it online but I got mine from a local store where they were promoting it. If you have to wipe the coach you might was well use a cleaner/polish
RV Park Finder
Fulltimers
2002 Beaver Santiam 38DST + Banks + 99 Jeep GC
DH,DW,Jake and Indie
CaBoy
Junction City, OR USA
Cramalot, sounds like you have tried a few things. Please let us know what you end up with for best results and effectiveness. Thanks & good luck.
The older I get, the better I used to be.
1997 Prevost by Country Coach
470 HP Series 60 Detroit / 6 SP. Allison
2005 Jeep Grand Cherokee Toad
Same Co-Pilot for 43 years
2 Boston Terrier girls, Scooter & Mia
bnash
Tampa, FL
I would try Simple Green (full strength).... The product cleans almost anything....
2008 Damon Challenger 376
Cramalot
Arkansas
Thanks for the tips. I will try them when I get the motorhome back from the shop. They have part ordered for the converter.
