crazymcs
New York
i am looking fora long hose and connections to go from my quick connect on the side of my trailer where you can hang a RVQ. I want to connect it to my new weber Q. Does anyone know where i can get this. Thank you
2006 Tahoe
2006 Antigua 195CK
Dad and Mom, and baby
Cooler full of Beer
tandkj
Full timer
Often you can go to a propane dealer and they can make you one.
08 Camelot
07 Ranger Toad
One lost Golden Retriever
bill h
el segundo
Just a caution...........
Is your quick connect regulated or unregulated pressure?
Does your Weber take regulated or unregulated pressure?
They gotta be the same.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
javaseuf
Southern Cal
Sorry, it will not work unless you remove the Q's internal regulator because the Rvq outlet on your RV is a low-pressure connection and the stock Weber Q is a high-pressure set-up. If you use a hose that screws onto the Q's small-bottle connection and then connect it to your RVQ fitting, the grill will be "double-regulated" and will not work.
Easiest way to use the Q is by using a small, separate bulk tank with the proper hose or us an Extend-A-Flow that mounts between the RV's propane tanks and regulator so you have high-pressure to the grill.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Wherever I happen to park
www.marshallbrass.com and check on the RV link
Wiscampsin
Wisconsin USA
A local LP place fixed me up with an extension for our RVQ. If you check the link below you can see where the splice is, top of pic, between the original RVQ hose and the extension part.
http://good-times.webshots.com/photo/2643492580101502272xKNYWx
2006 Toyota Tundra DoubleCab
2007 TrailCruiser C243S (traded in)
2008 Jayco Eagle 314BHDS
http://community.webshots.com/user/wiscampsin
javaseuf
Southern Cal
Nice but it will NOT work with the Weber Q. Your RVQ is a low-pressure grill. The Q is high pressure. Hose doesn't matter.
