RV.Net Open Roads Forum: Technology Corner: tv antenana
 > tv antenana
mikeshelor
riner va
Posted: 05/04/08 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
im putting a new lcd tv in my tt 2005 model will the roof mount anteana from factory work
HarryWM
Wherever we are parked this time.
Posted: 05/04/08 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
It should, assuming you are in range of a TV tower. Cable routing should come from roof antenna thru booster (also has 12V DC outlet) to your set. Assure booster is turned on (normally a little light bulb).
Harry
With wife Carole 10 yrs fulltiming
Retired U.S. Army
2002 Carriage LS 37' 5er; 2006 Lance 1181
2008 F-450 King Ranch 4x4 fully loaded
2004 Jeep Grand Cherokee toad
SKP # 54751
Geocacher "DosTortugas"
Harry's BLOG
luvlabs
Frederick, MD
Posted: 05/04/08 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
It will work like a champ. I recently visited one of my favorite campgrounds that, if you didn't have satellite TV, you didn't have TV. Guess what, the good old bat wing pulled in those digital channels with ease. The analog channels were still fuzzy, but I was completely surprised by the digital reception.
Carriage Cameo 33CKQ | 08 GMC 3500HD CC LB Duramax Dually | Sam the Cat and the Labs | Best wife going
jorbill2or
Oregon
Posted: 05/04/08 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
remember digital is for the most part a UHF transmission and UHF antennas are very directional (the bat wing is a Combo Vhf /Uhf antenna) so if not pointed at the station tower, the signal may not be received well. Find out where most towers near you are and point before you run the auto tune function avail on most Tvs' antennaweb.org is a good site to use.
Bill
2000 Ford f250 7.3L 6sp man 3.73
ride rite airbags
2004 everest 343L
Wherever I happen to park
Posted: 05/04/08 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
YES.
The rule is this.. Digital TV is the same, to the antenna as UHF in some markets
IN a few markets it will be UHF with VHF-High band
So if the antenna works now for channels 7 through 69, It will continue to work on the REDUCED band that digital uses
By the way.. I've seen folks post links to charts and such claiming that these charts show the channel assignments for digital come next year
They show the CURRENT analog assignments, not the forthcoming digital ones
I've also seen the sale notice on channels 60-69 and 2-6
Digital uses 7-59 and in most markets just 14-59 or less
So any antenna that works now, will work next year
 > tv antenana
