kraushad
Eastern Panhandle, WV
Yeah isn't it though? It's new this year, up until I traded my TV for a new one and wanted to update my sig pic, you could actually see my rig
I have read that the servers are having trouble with newer sig pics - it meets all the size criteria...
EDIT: HEY I GOT IT TO WORK - just uploaded it again at this time it took - sorry no red X to admire anymore... I thought it was the server, but this time it worked.
edited 05/05/08 07:27am by kraushad *
Dirk
Myself (34), my Wife(32), and "The Boy"(3)
06 GMC Sierra 1500 Crew Cab, 5.3L V8, 3.42rear
05 30QBSS Trail-Cruiser, Prodigy BC, Reese Dual Cam W/D
campin4kids
Indiana
Thats where our water pump switch is located.
Deb
Steve and myself
our 4 kidlets, Justin-15, Rachel-12, Michelle-10, Kellie-8 yrs old and
our Yorkie Tiffany-3
2002 Black 1500 Avalanche 4X4
2007 Sun Valley Road Runner 210 bunkhouse
gnj1958
Corpus Christi, Texas
kraushad wrote: gnj1958 wrote: I think it switches on your flux capacitor. Did you find yourself traveling back in time whenever you switch it on? If not it may be faulty. Don't worry though, all you have to do is feed 1 gigawatt of electricity directly into the coil.
Uh, I hate to correct you, but shouldn't the calculation be 1.21 gigawatts?
That was the old models. The new ones don't require as much power.
Glenn & Jenn
3 dogs Cody, Dudley & Mogwai
04 Chevy Tahoe LT V8 5.3, 3.73 (HA)
05 Keystone Springdale 256 FBL
gnj1958
campin4kids wrote: Thats where our water pump switch is located.
Deb
Well he says he can't notice anything happening when he switches it on so I doubt it's the water pump. If his water pump sounds anything like ours.
naturist
Lynchburg, VA
Nah, it turns on the pump that supplies the blinker fluid to the turn signals.
kraushad
gnj1958 wrote: kraushad wrote: gnj1958 wrote: I think it switches on your flux capacitor. Did you find yourself traveling back in time whenever you switch it on? If not it may be faulty. Don't worry though, all you have to do is feed 1 gigawatt of electricity directly into the coil.
I guess everything is going green these days
Thanks for the update.
dup4fun
NY
See if there is a outlet up by the top of your awning. A friend of mine has a switch like that and it control a outlet up ther for awning lights. Her camper is a crossroads
2008 Jay Flight 30 BHDS 07 Silverado 2500HD & 02 Trailblazer
Me 46 the Boss 43
DD 15 & DD 12
Brichon-Frize
Blue & Gold Macaw
Riverdogrj
Mead, WA
LoudRam wrote: We do have a DSI water heater but the switch for that is on the control panel.
I turned that switch on tonight with a fan running in the camper and the fans output dropped a little so it turned something on. I'm pretty sure we had the switch off this whole time. Thankfully when the previous owner winterized it, he filled the water heater with anti-freeze. I guess at worst I might have cooked the anti-freeze. I guess we'll see this week when I de-winterize it. I'll fill the tank with water this week and see if it heats it up. Thanks for all your help and if you have any more advice keep it coming.
I hope you didn't cook the anti-freeze as it leaves an awful taste in the water system that takes a bit of work to get out. I bought a used camper a few years ago & did just that. I can't tell you how many bleach/water flushes it took to finally get the system get back to normal but it was quite a few.
2004 Chevy Silverado 2500HD -- Duramax/Allison
1997 Sandpiper by Forest River 25FLS
1989 Honda Goldwing GL1500
Tekonsha P3
Equal-i-zer
Loopy
Western Pennsylvania
Putting antifreeze in the hot water tank AT ALL leaves a bad taste in the water for a long time.
You need to bypass the hot water tank when winterizing.
Bryan , Jess , and our Parsons Russell Terrier, Melvin
1999 Chevrolet Tahoe 4D 4WD 5.7L 3.73" Rear End
Reese Strait-Line Dual Cam Weight Distribution Hitch
Tekonsha P3 Brake Controller
2008 Jayco Jay Flight G2 20BH and Mods
Mike Schriber
San Diego, CA
Weird. My first guess would be a exterior outlet, step light or dump valve light.
Good luck!
Mike
2005 Chevrolet Suburban K2500 LT (8.1 liter with 4.10 gears)
2004 Starcraft Homestead 29BHS (16,000 pounds combined)
Twin Honda EU2000i Generators - 12' Porta-Bote
Prodigy / Putnam XDR / Equal-i-zer
SoCal Family Campers
