RV.Net Open Roads Forum: How to quiet a noisy water pump?
 > How to quiet a noisy water pump?
Daveinet
il
Posted: 05/04/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Some noise is good. If you have a valve that leaks, you want the pump to wake you up in the middle of the night. Noise is much better than an overflowed toilet.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
730
Tennessee
Posted: 05/04/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
i agree ,, what is with the noise problem any way ,, my alegro bus has a noisy water pump ,, but it don't bother me ,, if u hear a little rattling ,, so what ,, turn up the tv ,, sorry ,, it's just MO on the the water pump thingy ,,, and yes it would be better to hear some noise from it ,, as the above posted ,, better noise ,, than a flooded MH ,, IMO
No Shoes, No Shirt, No Problems, "My Way Of Life"
rltorpey
The land of taxes
Posted: 05/05/08 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Twomed wrote:
You said "insulated" the lines?? Shurflo calls for two feet of flexible water line (reinforced hose) between pump and hard lines. This will get rid of the noise.
I haven't done anything about mine yet but this is what I was planning to try. Thanks for the info. I guess I'd better get a "roundtoit" and get the job done.
Robin & Laurie
4 yr. old granddaughter Mercedes
'04 RAM 2500 QC, 4x4, SWB, Hemi, auto, 4.10 LSD, power trailer mirrors
'06 McKenzie Starwood 29RES fifth wheel
phnguyk
NJ
Posted: 05/05/08 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
With mine mounted under the rear queen it was annoying to say the least. Simple test, take the four mounting screws out completely and turn the pump on. Mine is nearly inaudible now even the line pressure noise is gone. The noise is actually the vibrations reverbing(something like that) through the screws into the coach frame. Think of those kids toothbrushes that play music through their teeth. To be on the safe side I had enough room to put a rubber strap over the pump and screwed that down. Hope thay helps.
LK23
Colorado
Posted: 05/05/08 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
phnguyk,
What did you do to quiet the pump?
Itasca Horizon 40AD
Honda CRV toad
chuck4788
West of the Middle
Posted: 05/05/08 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Been there: All of the previous suggestions help. The pump vibrates and transmit the vibration to the water (and then to the pipe) and to its mounts.
I had vinyl lines so I mounted the pump on a piece of plywood and rubber mounted the plywood to the floor with long screws and a stack of grommets on both sides of the plywood. It kinda floats on rubber.The pump mounts transmit vibrations at a different frequency than the grommets so the double mounts compliment each other.
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
Diplomat Don
Moorpark, Ca
Posted: 05/05/08 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
All the suggestions are good. I have the 5.7 Shurflo mounted on an old mouse pad and rubber grommets to the plastic floor of my water bay. I also added the 2' of flexible hose. Mine is very quiet, but is also below the double insulated floor level.
One last thing you may want to try. Follow your plumbing the best you can and check under the sinks and in closets to see if it's touching up against walls. If it is, put some foam insulation around it where it touches. A lot of nosie comes from the piping banging against the walls in various areas.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2007 Dodge Dakota 4WD
LUeno
Southwest
Posted: 05/05/08 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
Noise? What noise? I'm happy it's working....
LUeno
From the Mojave where the birds fly backwards to keep the dust out of their eyes.
Captain: Pops
Ist Mate: Harlee "Vicious Attack Dog" only if you try to move her when she's sleeping...
phnguyk
NJ
Posted: 05/06/08 07:08am Link  |  Quote  |  Print  |  Notify Moderator
lk23,
Just removing the screws quieted it right up. The noise was traveling through the screws into the coach floor amplifying the noise. It seems that the very slight twisting of the pump with the rubber strap when running lets the outlet line relax at the pump instead of further in the coach such as in the walls, ect..
SS Slacker
Lino Lakes, MN
Posted: 05/06/08 09:51am Link  |  Quote  |  Print  |  Notify Moderator
I bought the silencer kit from Camping World, which is basically just two soft lines for the input and output side of the pump. They make a circle and hook up to the hard lines that used to be directly on the pump. Made a huge difference in noise and vibration.
Dan & Tracy
2 kids ages 4 and 6
2003 HR Neptune 36PBD
300 ISB Cummins/5-Speed
