RV.Net Open Roads Forum: Travel Trailers: Electric Tongue Jack
 > Electric Tongue Jack
ScottG
Bothell Wa.
Posted: 05/06/08 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Barker 2500 on my 800 lb tongue and it has no problem lifting or even breaking the hitch loose from the truck when it sticks.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
rlc323
Illinois
Posted: 05/06/08 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Bought a Barker 3500 from Mantelli Rv on ebay. They shipped it about an hour after I paid for it. Got it yesterday by UPS and put it on this morning. Great people to deal with as their ebay feedback attests. The jack was a piece of cake to install. Running the hot wire from the battery the only real task to the entire job.
A note about some of the jacks on ebay. There are several that are "Factory Reconditioned" on there. Not saying anything bad about them, they are less expensive than new. But be sure to read the auction notes carefully when you are shopping so you order what you want.
2002 Chevrolet Avalanche 1500 Z-71
2002 Trail Lite 8261
smokestone52
Las Vegas, NV
Posted: 05/06/08 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
I am a little leary of Ultra-Fab right now. I dropped my TT off at storage yesterday, and the gears stripped on my UF 3000. Trailer tonge weight of 550. I have had the jack for one year. I will be taking it off in a day or two and I am going to send it in a see what they will do. I have been really careful with mine, and never reversed it during a cycle, and have always kept it dry. I had to use my truck jack to get my trailer off, and then every piece of chalking and wood I had to set it back down. What a pain. Thank heavens I still have my old manual tonge jack.
06 F-150 Lariat 4X4, 5.4, 3.73 rear. Reese WD, and sway. Pulling,
06 Pioneer, 180CK, with air.
smokestone52
Las Vegas, NV
Posted: 05/06/08 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Ya know, I also got to thinking.(scary huh) Maybe the best way to go would be a GOOD manual jack. I suspect the manufacturers put the cheapest jack possible on their trailers. The problem I had with my manual jack was it took 50 to 100 turns to get it up, then back down, then up at the campground, then down, then up and down, sheesh, I should have had Arnie arms!
But my question is this. Is there a good manual jack made with good gearing, to where a person can make maybe ten or twenty turns to get it up and back down or what ever?
cachingcampers
Niagara Region,Ontario
Posted: 05/06/08 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
A friend bought a "Reconditioned UF3502" from Mantelli's on Ebay, he experienced the same problem. I bought the "New" Barker 3000 from Mantelli's and have NOT had an issue.
BTW...Jay @ Mantelli's did fix my friend up with a replacement, no trouble, but still a hassle JMHO.
2008 KZ Sportsmen S272LE- Equal-i-zer,Prodigy,Barker Hi-Power. Towed by a 1999 Ford Expedition "Eddie Bauer" 5.4L Triton V8
Me-1970
DW-1967
DS-1995
Our Pics & Trips
chris0275
West Palm Beach Florida
Posted: 05/07/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Update: I got some time today to drive out to my TT and put the new Bulldog 4000 pounder on. I hooked up my TV, removed the three bolts holding the old manual one on and in less than 5 mins had the old one off and in the storage compartment(just in case). I opened the box and pulled out the new electric jack. The jack slid easily into the first hole on the top and stopped about 2 inches away from where it should be. I looked underneath and found that the bottom hole was just a hair smaller than the top. A few minuets later with a grinder and my drill, the hole was big enough to bottom out the jack. Three bolts in with lock washers, and the nuts underneath secured it in place. I ran the wire along the shaft, and zip tied it all the way to the battery giving a neat appearance. Hooked her up to the battery terminal using a new connector, and viola, no more hand cranking for me. My buddy got there just in time to see me hooking it up. Needless to say he is ordering one now and I will be helping him install his in the upcoming week!
smokestone52
Las Vegas, NV
Posted: 05/07/08 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
I took my UltraFab off today. There was a washer and ground up gears and grease in the bottom of the tube. I was hammered.
I won't even bother with this jack (trash) I will find a good one next time!
smokestone52
Las Vegas, NV
Posted: 05/07/08 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Oh by the way. Who builds UltraFab. No one seems to know. I suspect a Chinese connection here, or worse.
rlc323
Illinois
Posted: 05/07/08 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
According to the information on the Mantelli ebay auctions the Ultra Fab line is imported, no indication of from what country. Barkers are made in the USA and even sport a sticker on the front of the jack that says so.
dawg37179
Thomsons Station, TN
Posted: 05/07/08 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
I ordered a Barker VIP 3000 from Mantelli's on Ebay today. As stated above, I had a UPS tracking number within an hour of payment! I'm really excited for it to get here so I can install it and check it out!
I will post back with my thoughts after all is said and done...
