RV.Net Open Roads Forum: Travel Trailers: Trailer tire pressure
 > Trailer tire pressure
LuckeyUs
Southeast Florida
Posted: 05/06/08 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Do you keep the trailer tire pressure at max or under the max? I've heard reasons for both.
Kenney & Jackie
Finally retired!
2007 Chevy Silverado 2500HD
4x4, Z71, with Electric steps
Hensley Arrow, Barker Jack 3500
2006 Jay Flight 322FKS
tvman44
Southwest Louisiana
Posted: 05/06/08 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend max according to the label on the tire as most trailers have the tires loaded to near their max rating.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
smokestone52
Las Vegas, NV
Posted: 05/06/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
If the tires are cold, or not driven more than say a mile or so, I would bring them up to max pressure or maybe one or two pounds lower. Never higher. If they are hot, never let air out to your max, because they will be low. My understanding is, RV tires build heat like crazy if they are low, and could self destruct.
06 F-150 Lariat 4X4, 5.4, 3.73 rear. Reese WD, and sway. Pulling,
06 Pioneer, 180CK, with air.
needgas$$
Westland, MI
Posted: 05/06/08 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
This is exactly correct.
Me & Her
3 of them, Dog
2006 Dodge Ram 2500 Quadcab/hemi/3.73
Reese Dual Cam HP
2004 Puma 30DBSS
skipnchar
Topeka Kansas USA
Posted: 05/06/08 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
The actual tire pressure you NEED is determined by your tires themselves and the weight of your trailer. It is NEVER a bad idea to inflate to maximum but not necessarily required. There is a WIDE VARIATION in "trailer tires" and the devils ALWAYS in the details but you have not provided any.
SuperDutyMan
Western PA.
Posted: 05/06/08 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I've wondered that with the new TT,my TTs GVWR is 7900 ,my axles are 5000lb each and my tires are rated at 2540lb each,so I have a one ton cushion on everything,but I have been runnuing them at max.preasure.My truck tires have a max.of 80psi but I do not run them at that full presure especially the fronts it handles and drives the best at 65 in the front ,75 in the rear.
2008 Keystone Cougar XLite 29RLS
2006 Super Duty V10 6 Speed 4.10S Tow Command Tow Pkg. 4X4
meh150
Syracuse NY
Posted: 05/06/08 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
A mechanic I know told me to run mine at max because they are bias ply. He said that the bias build excessive heat when run low and can seriously damage the tire. Radials can be run lower.
chambers
Haliburton, Ontario
Posted: 05/06/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Tires should be inflated according to the weight they are carrying, up to the max shown on the sidewall. Goodyear has a chart on their website showing the tire capacities at varying pressures. If you need to inflate to the max, you might want to consider going to a higher load range.
BOB
Hornet28BHDS
Parker, PA
Posted: 05/06/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
I keep ours aired at 65 PSI.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
swebber
Brunswick , MD
Posted: 05/06/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Same here !
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
