boatsplus
plymouth,mn
I have a very unique situation. I have a one site only parking spot for my 5er which is for the summer months. The thing about it is there is no turn around at the bottom of the hill. No problem in the spring when I will bring it down there, but I'm just a little uneasy next fall when it is time to leave. I had no problem last year when I backed a 12000# 5er up the 30 plus degree grade, now I have one that weighs closer to 16000#, with an 06 F-350 6.0 CC SB FX4 18K Reese pushing it. The distance is about 100' backwards uphill. Will it get it done like I suspect it will without blowing something out? I've been backing up stuff all my life, but never something of this magnitude. Any expert advice is much appreciated. I'm more concerned with the hitch paying me a visit through the back window than I am with the truck unable to get it done. Thanks for your advice.
Boatsplus
2006 F-350 6.0 Lariat FX4 CC SB TP PP Draw-Tite 18K.
2008 Holiday Rambler Presidential Suite 37 Trail Air.
2007 Polaris Sportsman 800
2005 Polaris Sportsman 800
2002 Polaris 600 XCSP
31REHauler
Orangevale, CA
I checked your profile to see that you have a 4x4. If you put it in 4Lo you go to a 2:1 ratio which will allow you to move it easier. The only issue is if you have to turn too far off center while backing. As you know, 4WD tends to cause binding or bucking in the front if you have to turn too hard, depending on what surface you're driving on. You didn't mention what the surface is.
As far as the hitch visiting - I think it is strong enough for pulling and pushing. Remember the hitch takes a strain during braking. Yes, the 5er brakes are keeping the full weight off of it, but going slow up hill shouldn't put that big of a strain on the hitch.
JMHO
My Mrs., 2 Yorkies & Me in our "Rollin' Hotel II"
2007 Legends 31RE3SLF-5 by Pilgrim International
2001 F350 7.3L PSD SuperDuty CrewCab Long Bed 4x4
Prodigy BC & Reese 15K 5'er Hitch
Six_on_the_floor
Bakersfield, Ca
Is your 4wd ESOF or manual locking hubs?
I did not order ESOF so I could put the transfer case in 4 low and get the gear reduction without having the 4wd on pavement issues.
2004 Holiday Rambler 34SKD Presidential TT
1700# Reese Dual Cam
2005 F-350 XLT SRW 4X4 CC long bed 6.0 PSD 6spd manual
Gale Hawkins
Murray, KY
Put a hitch on the front.
Golden_HVAC
Fulltime, CA, USA
Hi,
With 4 wheel drive and low range, you are much better off than someone without 4 WD. The problem is how many horsepower the engine can make at only 900 RPM. It is actually very limiting. With a manual transmission, there is even higher limits, because the engine can not rev up while sitting still, like with a automatic transmission.
If you don't succeed on the first try, try it at a slightly higher speed, and the increased engine RPM should provide enough power!
If you don't have a transmission temperature gauge, get one! The transmission can heat up a lot when moving very slowly, especially when a lot of horsepower is going through the engine.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
glsurrat
Virginia
Gale Hawkins wrote: Put a hitch on the front.
It's a fiver.
Kinda tough to mount a Reese 18K Signature Series on the hood!
Greg
Full-timing and soon to be retired US Navy Master Chief
Enjoying Champagne on the King Ranch!
'06 King Ranch F-350 Dually Diesel 4x4 Long Bed Crew Cab w/ Tow Boss
'07 Champagne Edition NuWa Hitchiker 3 axle 4 slide 37CKRD /w TrailAir all around
boatsplus
plymouth,mn
Thanks for the replies. It is a straight shot with really no turning involved, and it is on pavement. The truck has both ESOF plus manual locking hubs. Probably the main thing is just make sure to do it the first time without stopping.
Any further advice is much appreciated.
boatsplus
mkirsch
Rochester, NY
If the hitch will pull the trailer without breaking, it will certainly hold up pushing the trailer, unless it's defective or improperly installed.
hotpepperkid
Chino Hills CA
Watch the transmission temp as it will climb very fast.
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
SoCalDesertRider
SanDiego, CA, USA
Put it in 4-Low with the hubs unlocked. If the truck can pull the trailer forward up the hill, it should be able to push it backward.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
