UNIMOG Dave
Santa Maria, CA
Hello:
This is the first of several questions I'll be posting. I have an '08 Cougar 268RLS TT and I want to replace several of the standard light fixtures with flouresent. However, another RV owner said some of them may need to be grounded. How true is that?
Anyone have any suggestions on where to look for fouresents? Camping World is a bit pricey.
Thanks
Dave T
1995brave
San Antonio, TX
Grouding is a new one on me. All the ones i've installed have two wires, +12vdc and -12vdc(common). Check out WWW.PPLmotorhomes.com for lights.
Bearnkat
Fort Worth, Texas
Grounding is a new one on me as well. We replaced our regular lights with 12 volt florescent one. We just pulled the old light fixtures and installed the new ones using the same wires, they work like a champ! We purchased ours at CW when they had them on sale and got a great deal on them.
Chuck & Terry
2005 Pilgrim 281RB-S
2006 Ford F250 Lariat CC 4x2 PSD
My Lap-Band Journey!
DFW/Central Texas Rally - Fall 2008
Chuck and Terry's Pilgrim Adventures
North Texas Camping Association
Lone Star Dutch Oven Society
axlloy
london ontario canada
I would agree - i don't think that grounding is an issue - but i am no electrician - just don't remember seeing a ground on them.
stupid question from me --- what is the major advantage of doing so - making the change to floursent fixtures? is it a heat thing or use of electrictiy thing?
curious
thanks
1995brave
San Antonio, TX
Less heat, less current draw from the battery, and more light output.
Mike Schriber
San Diego, CA
The lights are grounded already... that's the negative wire.
I added one fixture in my trailer for use when dry camping and it's worked out very well. It's very bright, starts fast and has good color. It also uses half the current.
Mike
2005 Chevrolet Suburban K2500 LT (8.1 liter with 4.10 gears)
2004 Starcraft Homestead 29BHS (16,000 pounds combined)
SoCal Family Campers
Prodigy / Putnam XDR / Equal-i-zer
SQWIB
Philadelphia, PA
I put a few in mine, Mainly for boondocking, but I like the light output better than the incandescants.
Midnightpumpkin
Concord Twp, Lake County, Ohio
You might want to consider adding a couple of 110V flouresent fixtures. Walmart has them for around $10.00, we have one over the couch and one above the kitchen sink. I was able to route the cords down by a window valence to hide them.
Just a thought.
John U
Midnight pumpkin
2003 Dodge Ram 2500, HEMI, 2WD, 3.73 gears, 5speed Auto
Prodigy Brake Controler
Reese Dual Cam HP
2007 Rockwood 8315SS Travel Trailer
Loaded Weights:
Trailer Axles 6640#, Hitch Wt 920#
Combined Gross Wt, no passengers, 13,855#
UNIMOG Dave
Santa Maria, CA
Hello:
To everyone, thanks for the input. The grounding thing came by way of a retired Air Force CMSGT who is now working as a civilian at Edwards AFB, here in Calif. Maybe working for the Air Force has corroded his brain.
Dave T
LoudRam
New Jersey
UNIMOG Dave wrote: Hello:
Dave T
The country club Air Force lifestyle tends to do that to people. Typical zoomie.
Todd
Desert Storm Vet (US Navy)
2002 Fleetwood Prowler Lynx 30'
2001 Dodge Ram 1500 Quad Cab 4X4 w/360 (not stock)
Predator DX2 brake controller
Equalizer Sway Control Hitch
If you can read this thank a teacher
If you can read this in english thank a vet
